Discourse Version 1.2
Focus
  • Extensibility (tagger plugin, akismet plugin, custom share sources)
  • Performance (Metal Views)
  • Emoji set choice / override / extensions ala Slack
Codename
  • Aeschines v1.1
  • Andocides ←
  • Antiphon
  • Demosthenes
  • Dinarchus
  • Hypereides
  • Isaeus
  • Isocrates
  • Lycurgus
  • Lysias
Start date
November 7th, 2014
Release date
Feb 19, 2015
28 Mi Piace
NEW FEATURES
  • Enforce 1 day expiry by default on discourse cache
  • Use HTML badge description on individual display
  • Carry username or email from login form to the forgot password and signup forms
  • 1 year anniversary badge
  • When PMing a user from the topic page, insert a link to the current post
  • Allow users to specify if prepared statements are allowed
  • Configurable connection reaping settings
  • Allow moderators to see flagged private messages
  • Import scripts update last_seen_at on users based on created date and last post date
  • Readonly safeguard
  • Prevent upload of more than 10 files at a time
  • Show large objects in admin/memory_stats
  • Filter screened IP addresses
  • Add process stats to memory report
  • Improve memory reporting of /admin/memory_stats
  • Make default locale settable during bootstrap
  • Failsafe, in multisite if a site is bad still boot up
  • New “Plugins” admin section with extensibility support
  • ‘reply by email address’ validator
  • Allow plugins to log staff actions
  • Mentions stream on user profile
  • Search your bookmarks using in:bookmarks
  • Dashboard stats for application traffic
  • Remove any .tar leftovers when backing up
  • Basic disk space usage stats
  • Rudimentary view tracking wired in
  • Recently used emoji tab
  • Show number of active users in the last 7 days on about page
  • ‘b’ as a keyboard shortcut for bookmarking a topic
  • Add an option to show custom user fields on profiles. Default is to not show them.
  • Background job to make sure emoticons aren’t too big
  • Allow simple selection for category badge styles
  • Logging out logs you out everywhere
  • Suppress digest emails for users not seen on the site for more than (n) days.
  • Optional top level bookmarks tab
  • Enable pagination of /posts.json
  • Latest posts endpoint at /posts.json
  • Print the time it took for the import to finish
  • Allow importing of unactivated users
  • Automatic group membership based on email address
  • Ning importer
  • Split group admin in 2 tabs (custom & automatic)
  • Rate limit invites for non-staff users
  • :gift: rate limit invites for non-staff users
  • TopicCreator now supports ‘pinned_at’ parameter
  • Allow for custom timezone in vBulletin importer
  • Support for profile pictures/background in vBulletin importer
  • Log username changes by staff
  • Add a global notice whenever emails are disabled (disable_emails site setting)
  • Bookmark topic button
  • Show bookmarked topics in topic list
  • Add liked and bookmarked classes to topic list item rows
  • Show bookmarked topics when doing filter=bookmarked
  • Support for filter=bookmarked and filter=liked in topic list
  • Add ?bookmarked=true for topic lists
  • Remove star concept from Discourse
  • Allow users to persist customization with &sticky=true
  • Add std /staff page link from /faq
  • Only expand globally pinned topics on front page
  • Sorting by op likes shows the op likes count
  • Show likes column if sorting by likes
  • Invite admin api has an optional param send_email which can prevent sending an email to the invited user. The api will return the password reset url so that the caller can send an email with it instead.
  • Maximize button for customization css/html editor
  • Default string buffer will use a raw template
  • Raw helper has access to parent and options view object
  • HasModule global helper to figure out if module exists
  • Remember last emoji group used
  • Add more details in user posts archive
  • :candy: cool transition when expanding lightbox
  • Default emoji override
  • Download user posts archive
  • More than 1 site customization can be enabled at once
  • Remove override stylesheet option, too confusing
  • Custom emojis
  • Load fewer topics in the topic list on slow platforms (Android)
  • Topics per page should not be configurable
  • Post chunk size should not be configurable
  • Source maps in production for JavaScripts
  • Export csv for all the logs
  • Support for emoji sets
  • New ‘site_setting_changed’ event
  • Auto-close topics based on community flags
  • Work-in-progress emoji selector toolbar item
  • In:private keyword for searching private messages
  • Search private messages option
  • Re-prioritize related so unread is always first
  • ‘delete user’ button in the user card in the admin section
  • Use actual time in preference >` email notifications’ instruction
  • Switch to GitHub email_reply_parser library and parse plain text email content
  • Rolls up 1.2.. IP ranges when number of entries >` 10
  • Allow creating admin and moderator accounts via SSO
  • Add Message-ID header to emails
  • Show card when clicking on avatar in admin user list
  • “Suspect” users list in admin.
  • Restrict some user fields for TL0 users when viewed by anonymous users
  • Implement SSO provider on Discourse so Auth can be farmed to it
  • Pass return_sso_url to SSO endpoints, for easier return
  • Export sso data if sso is enabled
  • Clean up unmatched email/ip entries after a year
  • Add topic status namespace in RSS feed
  • Log a new staff action when rolling up banned IP addresses
  • Roll up function for 123.456.789.* ranges
  • Serialize the fact we are https in about
  • API endpoint for inviting an admin
  • Localize SSO error messages
  • Export screened IPs list in a CSV file
  • Allow admins to search users using IP ranges
  • Log out user everywhere and refresh/redirect
  • Hide bookmarks but always show if post is bookmarked
  • Don’t limit registration from an IP address if a staff member has that IP address
  • Delete all accounts from this IP in the IP lookup modal
  • Add ?status=deleted querystring
  • Allow restricting API keys to a particular range
  • Show exact error for test email
  • Remove english korean slugs
  • Add category to Group Post Listing
  • Only limit new registrations from that IP if all the users from that IP are TL1 or TL0
  • Improve admin IP lookup dialog (add username/trust level/read time/topics entered)
  • New ‘maximum new user accounts per registration IP’ site setting
  • Add a button for staff to delete a user on their profile page
  • Added Pin/Unpin Keyboard Shortcut
  • Attempt to recover from corrupt markdown engine
  • Allow animated thumbnails
  • Add custom user fields in user csv export
  • Allow inline disposition on uploads
  • Users can see the raw email source of their own posts
  • ?include_raw parameter for /t/id/posts.json
  • Allow explicit rel=“nofollow” on links
BUG FIXES
  • It should be BadgeType::Silver
  • Group member pages only showing first 50 members alphabetically
  • Should not count disagreed flags
  • Error when re-bookmarking a topic/post
  • Emoji cache could get corrupt
  • HR in profile causing user badge to behave weirdly
  • Stop allowing nested SUP in topic bodies
  • Allow searching in PMs when “search this topic” is selected
  • Remove notifications on deleted topics from the stream
  • Bookmark topic was not working intuitively
  • Poll plugin wasn’t working when the OP was deleted
  • Category images were not using the CDN
  • Editing a PM should never change the category_id
  • Back button was wonky at times
  • About user count was off by 1
  • Do not show name in email if name on posts are disabled
  • Columns of uncategorized pinned topics shift when the topic gets unpinned
  • :sa: Pluralization rules were wrong lang keys
  • Default sort grantable badges by name
  • Minor, do not send access origin if not set
  • Couldn’t uncategorize a topic
  • Use overage to keep usercard from going off browser
  • Upgrade event machine
  • Category background in topic views
  • Downgrade pg to stop memory leak
  • Highlighting was not being applied after some rendering.
  • Return sharing sources in the same order as the site setting
  • Title could temporarily revert to the site name
  • Sub-categories with the same name had the same background image
  • Sometimes postChangedRoute could be triggered when torn down
  • Hide “error logs” logs from staff. Refactor admin menu HTML.
  • Only load S3 stuff when we need it
  • JSHint wasn’t validating ES6 files, this fixes a bunch of errors.
  • Auto-close time can be a date like 2015-2-22
  • Set base_url for usage_tips
  • View tracking needs to release data earlier
  • Make sure to observe shadowed settings when refreshing
  • :sa: Pluralization rules had wrong lang keys
  • refresh should work with shadowed globals
  • Uncategorized is showing up in title tag on topics
  • Use distributed mutex to prevent errors when uploading emojis in batches
  • Clicking an attachment link works only once
  • Broken gravatar link when using S3
  • Backup logs on Firefox
  • Debounce backup logs in order to prevent Firefox crash
  • ‘Invalid date’ in backup logs in Firefox
  • On upgrade via discourse docker client json not updating
  • Removing a group from a user was not removing primary group
  • Ember regression in read-only banner
  • Support adminPlugins resource even if no plugins use it
  • Dashboard report date range calculations include time zone, and application request data too
  • Ning json can have square brackets instead of commas
  • Remove g and m flags from autolink regex
  • Allow closing polls in multi-locale sites
  • Status route should be served as text not html
  • :sa: Allow closing polls in multi-locale sites
  • ‘all’ filter never de-highlighting
  • Send a PM to moderators when a post has been flagged as sockpuppet
  • Check for full name in invite email subject
  • Force font-awesome update
  • Subcategory url was incorrect in rss
  • Clean up after adding events. Fixes random test failures.
  • Category backgrounds were broken
  • In case a topic is deleted, allow us to serialize their posts
  • Don’t add constants for ES6 modules in plugins
  • Allow TL4 user to rebake post
  • URL encoding was not working for %23 in links
  • Message bus was causing constant redis growth
  • Quote whote post should insert at cursor position
  • The “too similar” check happened when trying to make a post a wiki
  • Uncategorized category was not loading updates in edit mode
  • Add Google Analytics code to crawler view
  • Not allow TL4 user to set staff color
  • Setting custom avatar would not work a lot of the time
  • Auto orientation code causing grey images to appear blackish
  • Toggling staff color on a post doesn’t change button text
  • Toggling staff color on a post doesn’t get applied
  • The order of includes in the base importer was wrong.
  • Wiki editing was broken due to extra topic update
  • Resize event does not get cleared/unbind properly due to wrong usage of jQuery api.
  • Summary mode was broken and missing a bunch of posts
  • Creating a user shouldn’t error when optional fields aren’t given
  • Don’t require login to view post raw
  • Don’t submit read-guidelines for anonymous users (causes
  • Don’t pass nil to an array serializer
  • Use CDN for user card/profile background and user avatars (for real this time)
  • Strip whitespaces from user email
  • Allow developer emails to bypass email blacklist/whitelist restriction
  • Should flush rate limit keys before testing it
  • Adding a custom emoji needed an application restart to work on the server-side rendering
  • Pasting image in the composer wasn’t working in Chrome
  • Remove custom Discourse headers in email
  • PMs were not allowed to be edited in some cases
  • Upload on IE9 wasn’t working :cry:
  • Make sure we set a default name to a pasted image only on Chrome (the only browser that supports it)
  • Use “.json” extension to uploads endpoints since IE9 doesn’t pass the correct header
  • Pass the CSRF token in a query parameter since IE9 doesn’t pass it in the headers
  • Display error messages comming from the server when there is one over the default error message
  • HACK around IE9 security issue when clicking a file input via JavaScript (use a label and set visibility:hidden on the input)
  • Hide the “cancel” upload on IE9 since it’s not supported
  • Return “text/plain” content-type when uploading a file for IE9 in order to prevent it from displaying the save dialog
  • Check the maximum file size on the server :boom:
  • Always set a default Message ID in email
  • Creating a user shouldn’t error when optional fields aren’t provided
  • Don’t restrict to local filesystem for df check
  • Check correct directory when looking at backup limits
  • :sa: Use site-wide locale for deletion stubs
  • Loading of Emoji files depended on working directory
  • Language was not being inserted into RSS
  • Remove unused variables
  • Accessing an undefined variable is not a good idea
  • Minor Admin bug with a setting when creating a new group
  • :arrow_up: update onebox gem for more dailymotion.com support
  • Make sure pasting an image in the composer is considered as an image instead of an attachment
  • Groups post page was broken.
  • Posts weren’t highlighting on initial load
  • Full user names were showing up in crawlers and rss feeds in spite enables_names setting being disabled
  • Months were not getting translated
  • User name and title were not showing on post creation
  • Clear the user-selector when adding new members
  • (for IE9) if console.log doesn’t exist, make it an noop.
  • Don’t break import when raw can’t be preprocessed (vBulletin importer)
  • V8 issue with regexp
  • Respect user locale for reply notifications
  • Suspended users are logged out when they are suspended. Show a reason for suspension when they try to log in.
  • FIX TopicQuerySQL to support pinned topic older than 2010
  • Properly remove all HTML Entities from Usernames/Titles/Category Names/Groups in vBulletin importer
  • Properly handle specific vBulletin BBCode (quotes/mentions)
  • Make sure we generate a username from the name of the user instead of a fake email
  • Merge the categories tree to only 2 levels in vBulletin importer
  • Convert UTF8 charset to UTF-8
  • Move vagrant box to discourse hosting
  • Update vagrant box for ruby and phantomjs versions
  • On topic page, don’t try to render post counts for a deleted user
  • Saving the same custom field array twice would raise an error
  • Supress the category badge even when refreshing
  • Triggering a refresh while subcategory lists was broken.
  • Ensure emoji are case insensitive
  • Show email button wasn’t working on user’s profile page
  • Posts weren’t highlighting when jumping using the progress widget
  • Activate account page JS error with I18n
  • Old csv’s were not getting deleted
  • User list export was failing
  • Remove Bookmark was broken on bookmarks page
  • Handle timezone detection errors
  • Jump to post was not respecting gaps
  • Users tab in admin panel doesn’t stay highlighted
  • Bookmark button is now solid black by default & blue when bookmarked
  • Background fade-in for modal dialogs
  • Forgot i18n associated with bookmark button (:fired:)
  • Check free space in uploads directory, not global system
  • Missing bookmarks from user actions
  • All PMs should be flaggable
  • Making sure {{fa-icon}} don’t break when we’ll update to latest ember
  • Emoji rebuild when changing emoji set for the 1st time
  • We missed some references to /category/xyz in the ruby code base.
  • Un-delete topic wasn’t working
  • Emoji toolbar wasn’t showing up after a page reload
  • Each helper in raw templates
  • Properly order pinned topics
  • Deactivate check was removed from JSON by accident
  • Issue with Vagrant image failing specs.
  • Proper handling of group memberships
  • Dashboard should be warning about invalid notification_email site setting
  • Deliver discourse stylesheets over cdn
  • Link domains were not showing up in the topic map
  • Rss link in category pages
  • Show only staff actions in export and hide site setting logs from moderators
  • Category not hidden correctly
  • Don’t truncate groups. @ZogStrIP we need to create a better fix for
  • Rate limit user posts export
  • Multisite CDN support for site customizations
  • Don’t use CDN for customizations
  • JsHint fail
  • Keep topic list items on screen when using keyboard.
  • We should only intercept enter as a keypress when a selector
  • Use utc time when generate reports; set boundary
  • Allow [poll] and [ul] to be used as markdown link name
  • Users should be allowed to add @ to the to field of a PM
  • Markdown bug when a heading preceeded a code block.
  • Site setting search
  • Today visits not shown
  • Deleted topics were failing user posts archive download
  • Some query params were showing up as undefined
  • Clicking on pin/unpin would refresh the page
  • Use prefixes for CSS transform
  • Hide emoji toolbar button when emoji are disabled
  • User card can’t expand when the username is number
  • Log only 1 ‘show email’ record
  • Cache emojis for 1 year
  • Proper redirection when deleting a user
  • 1.9 regression on i18n strings with variables
  • Load custom emoji API before the plugins
  • Buggy unhoisting of escaped *
  • No way to remove site text
  • More robust site customizations
  • Stable ordering for site customisations
  • Custom emoji weren’t properly baking
  • Use cache to store custom emoji
  • Only create animated thumbnails for GIFs
  • Don’t pop up “cancel” when returning to topic
  • Sane badge ordering on user page
  • 1.9.0 regressions with i18n
  • Reduce verboseness of uglify command
  • When private messages are disabled in settings, flag modal shouldn’t show private message options
  • Sharing buttons broke in 1.9 template upgrade
  • Not highlighting posts when entering a topic
  • Should be 30 topics on desktop, 15 on android
  • Safari 7 changed popstate behavior
  • Regression with ember upgrade on notifications
  • Regression in badges linking to a post
  • Sometimes loading blank topic list
  • Add topic-owner class to all the posts created by the OP
  • When using {{avatar}} within autocomplete
  • Redirect client to the original url after logging in for private in…
  • Automatically use uploaded avatar when uploading an avatar
  • Redirect client to the original url after logging in for private instances
  • Registration fails with timeout on gravatar
  • Don’t raise an error when trying to log nothing
  • If a user uses the keyboard to navigate, don’t bubble up the event.
  • Semantic HTML for category with images
  • Upgrade Ember List View to add 1.9 support
  • LazyYT was not being applied when a post was edited
  • Polls were broken after Ember upgrade
  • Load order of Javascript
  • Category badges were missing stripes in some places
  • Custom flags not possible on very long topic titles
  • Translations from plugins weren’t properly merged with default translations
  • Text in select2 dropdowns should not be variable since the
  • Properly unescape HTML entities in excerpts
  • Cache all public resources registered by plugins.
  • Add CDN support to emoji preview and toolbar
  • In Firefox :w autocomplete was broken
  • Fix rerendering issues on some components.
  • Javascript error when uploading backup
  • Remove links and html ‘hellips’ from topic/post summaries
  • Use excerpt instead of the summary
  • Drastically simplify auto-close topic logic
  • Broken HTML (thanks HTMLbars)
  • Share popup on mobile layout went outside of viewport, and z-index was behind user avatars. Use a real link on touch devices instead of a text input.
  • Auto response email replies should not be accepted
  • Disable loading below HTML, we have our own spinner for that and it
  • Permalink redirect support for url’s with extensions in them, like .html and .php
  • Errors due to _elementCreated called on null
  • Selecting default option without changing HTML markup.
  • If a category can’t be found, don’t include it in the list
  • Couldn’t click delete topic button due to missing action
  • Only show “new pm” in pm tab when looking at your own profile
  • Broken comboboxes. Workaround Ember bug that needs triaging
  • Check if the bio_cooked exists before outputting it.
  • Word null appearing in user card
  • If we are scheduled after being torn down don’t do anything
  • Don’t show undefined in the footer text.
  • Reload current page when deleting a user
  • Private message button wasn’t adding the recipient (cc @gdpelican)
  • Change top score formula
  • If full user name is not provided, username should be present in email From header
  • Better protection for invites scrolling
  • Selecting one user in admin would select them all
  • Clicking avatars broke for non-admins
  • Editing a category definition topic was clearing its permissions
  • Editing the 1st post of a private message wasn’t working
  • ExportUsers action was deleted, so user export was failing
  • Don’t error out when updating a topic with no changes
  • Hide restricted profile info from TL0 users to anonymous in ‘JS-off’ page
  • Roll up staff action wasn’t working
  • Don’t lose focus on site settings text field (was changing routes
  • Use OR query instead of AND, also check that the profile is
  • Auto-closing attribution when a TL4 user auto-closes a topic
  • Click counter for attachments
  • Load order issue / header category badge when not surpressed
  • Suspended users should have links stripped from their profiles.
  • Don’t show the banner topic on error page
  • Topic referrals by user were wrong
  • Changing category shows error for TL3
  • Admin panel referral stats not counting topics correctly
  • Display total number of other accounts with the same IP address in the IP lookup dialog
  • Limit other accounts deletion to 50 accounts otherwise it’ll feel too slow
  • Mailing list mode was not checking for user deleted posts
  • Sharing link stood visible after using browser’s back button
  • Cleanup commas in email From and Reply-to fields
  • Make IP lookup available to moderators
  • When adding an IP to the spammer list, check the broader ban list
  • Sso with avatar override may fail on first account creation
  • PM title not editable
  • Expire stylesheet cache on save
  • Could not download exported data on some sites
  • Make user_id uniqueness check pending. It still seems to check
  • Don’t crash from observer if user record is bad
  • Handling of “indexStream” in user pages
  • TL4 flag on TL0 post as spam, hides the post
  • Limit the number of group members returned for automatic groups
  • Don’t limit the number of group members returned to the front-end (UI needs some work for large groups)
  • Correct old username index
  • GroupedView bug with latest Ember build
  • Expanding replies not working correctly
  • Damn timezones
  • Try a different way of removing use strict from Ember 1.7.1
  • Remove use strict from ember build to get around iOS bugs
  • Do not display EPOCH
  • Changing category within edit grace period as TL3 pops up an error
  • Change is_staff to is_admin for group posts to match other places
  • Change is_staff to is_admin to match other places where guardian.allowed_category_ids is used
  • Do not recall prior DRAFT in a given category when using the Create Topic keyboard shortcut
  • Improve use of loading spinners on discovery routes
  • Inconsistent loading of user profiel page (expanded/unexpanded top
  • Distributed cache leak and potential infinite loop
  • Don’t use a process cache in development mode
  • Proper hack to support underscores in URLs
  • Couldn’t click on avatar on private message list
  • Support for underscores in URLs (when using S3 storage)
  • Change the unlisted/invisible topic state only when unhiding the first post
  • Remove grouped-each helper. GroupedView is deprecated in Ember
  • Missing styling for embedded reply
  • Don’t put the footer insider container in topic page
  • Don’t put the footer inside a container (allow for full width footers)
  • Official benchmark crashing while populating db
  • New topics were not showing in suggested
  • Missing tab delegation
  • 1000 was a crazy threshold for showing categories at the bottom of
  • Shouldn’t overwrite styles in emails that we explicitly set, like category
  • Don’t use auto sizes for very small images (emoticons)
  • Strip the word “SECURITY” from the output too
  • Include security in release notes
  • Don’t include reverts in release notes
UX CHANGES
  • Change user visits stat position
  • Add user invite link on admin interface
  • Add confirmation dialog for user archive export
  • Add a dash for the empty cell.
  • Use :star2: icon for recently used emoji tab
  • Fix ‘revision details’ styling in revision history window
  • Alwasy skip headers on topic lists on mobile.
  • Update 404 page category badge to use centralized helper and style
  • Max width of .gifv videos
  • You should be able to tab to the “This is a warning” checkbox
  • When oneboxing a topic, use the stripe category badge
  • Formatting on search categories looked weird
  • Change category badge style to use stripes
  • Add file size in CSV export notification
  • Change private category to lock glyph
  • Add class to gutter links so you can infer if they are inbound or outbound using CSS
  • Let’s try an animating heart out
  • Banner topics should be readable even with dark color schemes.
  • Make category link text black in digest emails
  • Link categories in digest emails
  • Consolidate “Admins” and “Moderators” into “Staff” on admin users
  • Add confirm dialog when rolling up IP ban entries
  • Bold all the entries in the screened IP list that are more than a single IP
  • Suppress long cat names in cat drop down too
  • Suppress long cat names in topic lists
  • Use warning (nuke?) icon instead of trash icon
  • Hide share button by default
  • Improve ip-lookup modal
  • Improved our footer handling
  • Whitelist OpenStreetMap iframes
  • Fixes for group view
  • More spinner upgrades
  • Proper loading spinner on create account
  • Use new spinner when logging in
  • Use new loading spinner when uploading an image
  • Position loading spinner properly on user pages
  • Use loading spinner on notifications
  • Don’t delay spinner on topic lists or clicking home
  • Better footer handling
  • Focus on the user card when it’s rendered
  • In digest email lists of topics, show striped version of category
SECURITY CHANGES
  • Missed html escaping
  • Don’t leak topic title in the redirect
  • The SSO return_path was an open redirect
  • Don’t whitelist codepen as it is a potential vector for abuse
  • Don’t echo the “strategy” param returned by auto provider
  • Prevent direct download of backups
  • Update Rails to 4.1.8
PERFORMANCE
  • Allow background jobs to flush between requests in same thread
  • Remove eval cause it is costing lots of memory
  • Only load locale files we are using
  • Remove addressable gem, its consuming huge amount of memory
  • Properly pass topic_id to post action cache to avoid excessive query
  • Slow user pages in admin. add an index for trust level 3 calculations, and memoize query results
  • Don’t bind all these things
  • Fix performance issue when displaying the user card for admins
  • Unify topic lists, remove star from lists, move to raw rendering
  • Improve rendering speed of topic header
  • Hold back rendering of suggested topics 1 run loop.
  • Do not generate source maps in ruby mode
  • Don’t render composer until we need it
  • Don’t render share dialog until we have a link.
  • Don’t render user card until displayed
  • Optimise rendering of posts
  • Don’t ever use inject on AR relations
  • Use preloader trick to load topic categories
  • Stop querying banner topic on every page hit
  • Use distributed cache for site text and category slugs
  • Distributed cache class to help sync caches between processes
  • Cache all site_text in memory
  • Remove superflous queries from initial page loads
16 Mi Piace
A feast of progress!
*trilling intensifies*
I admit to being a shameless voyeur on github, watching all these commits in real time (or close to it). It’s serial, episodic programming. I preempted watching season four of The Walking Dead for this!
1 Mi Piace
Guys you’re awesome! Huge work!
2 Mi Piace
Impressive list of new stuff.
For the clueless (me) what are Metal Views?
The trivial way of explaining is that there are no gazzilion <SCRIPT> tags sprawled through our HTML.
1 Mi Piace
Hi there,
I just upgraded (1.3.beta1) and I do not see the tag field. Is there an option to activate somewhere ?
Hi @Matthieu,
As far as i know, the tag functionality is optional. You can install the official Discourse Tagging plugin easily by following install a plugin instructions.
5 Mi Piace
Reading the official post from @codinghorror:
I have thought it was automatically included with the discourse 1.2 upgrade. Actually it just mean the plugin is stable.
Thanks @DavidGNavas for the install instructions.
1 Mi Piace
