Discourse Version 2.7
Focus
  • :white_check_mark: Improve “Markdown Typographer” so it is easier to modify and add -> to → rule(s). @Roman
  • :white_check_mark: Switch inline oneboxing from default off to default on
  • :white_check_mark: Optionally allow users to know when they were rejected. @kris.kotlarek
  • :white_check_mark: Rebuild topic timer UX to match bookmark reminder UX @martin
  • :white_check_mark: Improve login / signup UX @jordan.vidrine
  • :white_check_mark: Better handle login required sites under extreme load per topic @nbianca
  • :white_check_mark: Add linked words and replaced words into admin/logs/watched words, plus move auto silences per topic @nbianca
  • :white_check_mark: add “Do not Disturb” as an experimental feature @markvanlan
  • :white_check_mark: Support “Sign in with Apple” per topic @david
  • :white_check_mark: General overhal of invite system per topic @dan
  • :white_check_mark: Expose read history on user profile
  • :white_check_mark: Alert on dashboad for new Discourse features @pmusaraj
  • :white_check_mark: Support bulk actions for PMs @nbianca
  • :white_check_mark: Change composer icon (and submit button) based on selected action @osama
  • :white_check_mark: Automatically add anchor link IDs to markdown headers @nbianca
  • :white_check_mark: Warn in docker manager when an official plugin appears forked, per topic @nbianca
  • :white_check_mark: For more intentional admin and staff security around site settings, create a new HTML Site Setting type, and explicitly default all existing text Site Settings to plain text @Roman
  • :white_check_mark: Fire a webhook when a user is added or removed from a group @vinothkannans
Codename
Start date
Dec 1, 2020
Release date
May 18, 2021
NEW FEATURES
  • Add English (UK) as locale
  • Do not disturb
  • Use the site’s small logo as the system user’s avatar
  • Enable inline onebox for all domains by default
  • Optional filtered replies view
  • Add new features section in admin dashboard
  • Rename ‘Discourse SSO’ to DiscourseConnect
  • Topic timer UI revamp
  • Various improvements to invite system
  • Autotag watched words
  • Mailing list mode default disabled
  • Move site updated modal into a less obtrusive prompt
  • Allow setting avatar flair for automatic groups
  • Add anchor links to headings
  • Bookmark pinning
  • Admins can flag posts so they can review them later
  • The ability to search users by custom fields
  • New API hook to allow for client side upload transforms
  • Ability to register custom filters for posts
  • Allow sending a message with invite
  • Add email_encoded parameter to accept inbound base64 encoded emails
  • Add more class names to latest-topic-list-item
  • Add support for like webhooks
  • Always insert images on new lines and add newline after
  • Small improvements to the topic list embed
  • New ‘trim_incoming_emails’ site setting
  • Include avatar flair on the avatars listed in a user summary’s “Most…” sections
  • TL4 & category moderators can merge posts
  • Add reviewable score updated webhook
  • Allow using ‘top’ view for topic list embed
  • Share Topic modal improvements
  • Ignore anonymous page views on private sites
  • Allow theme tests to be run in production
  • A low priority filter for the review queue
  • New share topic modal
  • Show a notice if video cannot be rendered
  • Show a textarea in advanced mode
  • Allow pausing animated images in posts
  • Make category-navigation outlet tagless
  • Watch title for automatic tagging
  • Review every post using the review queue
  • Topic count in category boxes
  • Add plugin outlet for category-box-below-each-category
  • Show the slow mode indicator in composer
  • In the slow mode dialog make “Enabled Until” mandatory
  • Tweak slow mode messages and intervals
  • Allow setting postgres connection variables via environment
  • Reduce invite key length
  • Auto-activate users invited by email
  • Category setting to allow unlimited first post edits by the owner of the topic
  • Send an email notification when a post is approved
  • Adds last day to about page stats
  • Add user_confirmed_email to user event webhook
  • Make the tag_groups#search endpoint public
  • Trigger webhook when a user added/removed in a group
  • Use SVG icons for some oneboxes
  • Treat site settings as plain text and add a new HTML type
  • Introduce theme/component QUnit tests
  • Retrieve an existing link only invite
  • Add maximum limit for secondary emails
  • Copying invite link triggers a save
  • Use appEvents instead of jQuery for composer resizing progress
  • Show an educational message in the quick access menu for personal messages when there are none
  • Oneboxer cache response body
  • Allow admins to pre-populate user fields
  • Implement nonces for Google Tag Manager integration
  • Add new :topic_tags_changed DiscourseEvent
  • Treat emoji or similar characters as one
  • Import and export watched word
  • Add CSP frame-ancestors support
  • Add a typographer rule to replace ¶ with ¶
  • Implement browser update in crawler view
  • Check email availability in signup form
  • Add admin-area class to HTML tag
  • Allow users to save draft and close composer
  • Allow using invites when DiscourseConnect SSO is enabled
  • Obfuscate emails on invite show page
  • Replace markdown-it replacements rule
  • Fallback to system users when creating new TopicEmbed
  • Improve expired invites tab
  • Allow a cluster_name to be configured and used for /srv/status
  • Add above-timeline plugin outlet
  • New DiscourseEvent trigger for likes
  • Enable contact picker on new invite modal
  • Flag to disable DiscourseConnect CSRF protection
  • Add tag-custom-settings plugin outlet
  • Always show tag dropdown when tagging is enabled
  • Implement bulk operations for PMs
  • Allow category group moderators to pin/unpin topics
  • Allow search engines to index tag pages
  • Allow invites redemption with Omniauth providers
  • Change very high/low search priority to rank at absolute ends
  • Add newly loaded topics to bulk-select automatically if Select All is on
  • Add opt-in screenshots to the web app manifest
  • Move security related user preferences to different tab
  • Add year to relative time picker
  • Add a site setting to allow emojis to come from an external URL
  • Include details about S3 backup storage errors
  • Filter reviewables by id
  • Add site description for the webmanifest
  • Add disable_onebox_media_download_controls hidden site setting
  • Use the “time_read” stat to flag users as suspicious
  • Quick theme installs via query parameters
  • Use diffhtml to update composer preview
  • Support mark tag
  • Relative time input for timers and bookmarks and promote auto-close after last post timer
  • When moving posts to existing topic auto-select single topic
  • Allow onebox images to be used as topic thumbnails
  • Add “Recently read topics” tab to user activity page
  • Allow post/topic thumbnails to be prioritized via markdown
  • Ability to dismiss all new topics
  • Support keyboard back/forward navigation on DiscourseHub
  • Allow overriding the backup location when restoring via CLI
  • Ability to dismiss new topics in a specific tag
  • Handle user agent push subscription change events
  • Allow durations < 1 hour and < 1 day for topic timers where duration is specified (auto delete replies, close based on last post)
  • New way to dismiss new topics
  • Check blocked_onebox_domains setting for inline oneboxes
  • Improve group settings and members management
  • Add daily job to check for new features
  • Add contact emails metadata entry to optional plugin meta
  • Add extra response headers to nginx log format
  • Create notification schedule to automatically set do not disturb time
  • Give user menu icons alt attributes
  • Support DISCOURSE_SMTP_FORCE_TLS option
  • Replace single dash arrows when the typographer is enabled
  • Reason to reject user signup
  • IMAP detect spammed email and delete associated Discourse topic
  • Log when a group is deleted
  • Add before-groups-index-container outlet
  • Allow disabling self-deletions of posts
  • Warn admins when installing a theme that’s already installed
  • Send notification emails when users leave do not disturb mode
  • Disable post deletions by setting max_post_deletions to zero
  • Replace arrows when the markdown typographer is enabled
  • Add dash warning for using S3 without CDN
  • Introduce skip_auto_delete_reply_likes site setting
  • Explicitly ban outlier traffic sources in robots.txt
  • Special shortcut for searching for own posts
  • Adds support for the WEBP image format
  • Allow plugins to show custom HTML via renderTags
  • Allow plugins to preload custom data on search
  • Include post number in inline Onebox titles
  • Allow plugins to register demon processes
  • Allow IP anonymization via admin user controller API
  • Automatically disable slow mode
  • Allow category group moderators to list/unlist topics
  • Add likes, flags to user data export
  • Increase maximum watched word length from 50 to 100 chars
  • Support for GitHub Codespaces development
  • Link to text customization when editing system badges
  • Adds back button to theme editor
  • Add after-topic-list-body plugin-outlet
  • Reviewed by filter
  • Non-staff users can use shared drafts
  • Silently close topic
  • Allow Category Group Moderators to edit topic titles
BUG FIXES
  • Removes legacy Ember.keys usage causing a crash
  • Make replace watched words work with wildcard
  • Previewing themes didn’t work in Ember CLI
  • An unresolved blank uri should attempt an alternate Oneboxing strategy, if available
  • Automatically load more reviewable items.
  • Allow file-change events soon after reloading
  • Skip upload if HTML cannot be parsed
  • Make autotag watched words case insensitive
  • Wrong scope used for notification levels user serializer
  • Layout of date input in poll builder
  • Delete unconfirmed emails first if available
  • Missing iframe closing tag in discobot certificate
  • We should include resumable.js in the admin bundle
  • Make truth-helpers work in Ember CLI
  • Support pausing inline animated images
  • Various invite system fixes
  • Flaky specs after topic view custom filters
  • Properly filter ember-cli args
  • Recalculate scores only when approving or transitioning to pending.
  • Ember-cli proxy subfolder fix
  • Check trust level of user creating invite for group
  • Catch UndefinedConversionError for inbound emails
  • Remove auto-route from topic-link
  • Access to styleguide in subfolder install
  • Allow webp format on themes by default as well
  • Core templates should never overwrite theme/plugins
  • crypto.randomUUID is only available in newer node releases
  • Shared drafts should be disabled if Uncategorized was selected.
  • Do not try to show logo if it does not exist
  • Cache missing inline oneboxes
  • Prevent infinite loop when replacing watched words
  • Base topic details message on current category and tag tracking state
  • {{ace-editor}} was buggy in Ember CLI release
  • Use the no-sandbox flag when running Ember CLI tests.
  • Limit visible revisions history to last 100
  • Pressing back from topic in bookmark list takes user to /
  • Make the docker:test task install dependencies before calling yarn ember test.
  • Temporarily skip flaky future-date-input tests
  • Hide Uncategorized unless allow_uncategorized_topics
  • Link notification to first unread post
  • Show required only when full name is required and lint fix
  • Tag control styles should apply to desktop
  • Remove invite based associated object
  • Topic might be night at this stage
  • Show warning only if new value is different
  • Hide “Next Week” in future-date-input on Sundays
  • Prevents exception when text input is nil
  • Correctly use timeouts in FileHelper and FinalDestination
  • Wizard locale change wasn’t applying to some elements
  • Update max-width of staff log cells
  • Light color scheme picker should default to user selection
  • Looking up translation overrides by symbol failed when count is used
  • Prevents malformed href to crash TopicEmbed
  • Excludes .svg-as-img from JS sizing
  • Keep filter UI after editing post
  • Do not cut off long polls
  • Gracefully handle inline images in emails
  • Add theme field errors
  • Avatar flair wasn’t displaying on the user summary page
  • Improvements to animated image pausing
  • Ensures successive topic hydrates doesn’t override category
  • Recent regression meant we were proxying qunit when we shouldn’t
  • Ember CLI Live Reload was not supported by the CSP
  • Remove whitespace from theme git versions
  • No JIT when quoting a mention
  • Handle charset=windows-1252 in mbox import script
  • Replace use of regular expression
  • Make diffHTML handle external changes
  • Show staff bulk actions only to staff
  • Skip notifications about beginner badges
  • Bug when scrolling in iOS Safari with composer open
  • Forward all the HTTP headers through when we bootstrap Ember CLI
  • Ensures successive tags can be renamed
  • Allow moderators to access /admin/customize/watched_words
  • Ensure tag topic lists are not scrolled to an incorrect position
  • Do not add CSS transition effect to animated images
  • Send a different message if export fails
  • When a flag is handled archive message for moderator group
  • Exclude emoji images from JS sizing
  • Invalid Date on “last” shortcut for timer + bookmarks
  • TagDrop uses currentCategory now
  • Blank avatar on user card if flair url is undefined
  • Allow finding non-lowercase tag groups
  • Fall back to hardcoded version when period check disabled
  • Do not dump schema during production database migrations
  • Use CDN urls for theme settings of type upload
  • Revert color of post-map
  • If we want a .json path, don’t bootstrap
  • Use CDN urls for theme uploads
  • User group message route should not be case-sensitive
  • Clientside validate min tags for required tag group
  • POP3 polling shouldn’t stop after exception or old email
  • Enforce tag group count validation before sending to review queue
  • Allow CodeCommit-style theme .git url format
  • Update database_restorer to avoid shell use
  • Whitespaces when copying code blocks
  • Ensure plugin’s gems are in the gem path
  • Generate unique HTML heading names
  • Docking mixin was not cleaning up timers
  • Remove old usercard styles, fix bg img class
  • Show invite validation errors to users
  • Improve error messages for invites
  • Ensure the top 6 categories are shown in the user summary
  • Already sent headers error in Ember CLI
  • this.loading is undefined, it should be state.loading
  • Handle permalinks with query parameters
  • ember build was not adding digests to additional bundles
  • Don’t show the get a room composer message in private categories
  • Use Nokogiri and Loofah consistently
  • Improve anchor links
  • Software update prompt fixes and improvements
  • Topic user bookmarked column is out of sync after post moves
  • Allow raw-view classes to be resolved from themes/plugins
  • Only send user suspension emails if email message provided
  • Allow restoring non-subfolder backup to subfolder site
  • Automatically timeout long running image magick commands
  • Remove superfluous spaces from CJK blurbs
  • When user has already hit bookmark limit, do not error for clear_reminder! or other updates
  • Ensure group flair upload is present when deciding type
  • Dismiss new button for tags on top
  • Behaviour → behavior spelling in default US translation
  • Mobile topic list number alignment
  • Ensure software-update banner is only shown after 24 hours
  • Prevent double slashes in Ember templates paths
  • Make HTML scrubber work with deep HTML
  • Small tweaks to “no messages” education
  • Include watched topics from muted categories in digests
  • Keep current filter while navigating posts in a topic
  • Retain tags when loading a topic draft in composer
  • Show sign up modal when local logins are disabled
  • Clear state after creating new topic
  • New Topic button regression in tag page
  • Simplify send PM to email settings
  • Bulk select on full-page search
  • Rake themes:update should fail if a theme update fails
  • With vanilla js .href and getAttribute(“href”) are not equal
  • Rake themes:install error if theme cannot be updated
  • Downloading watched words was broken
  • Better error message for redeemed invite
  • “confirm new email” emails were failing for EmailChangeRequest records with blank requested_by_user_id field
  • Post merging was failing silently
  • Title when YouTube is pasted as the title to composer
  • Autocorrect values for dropdown imported user fields
  • Reload messages after a bulk operation
  • Handle staged users as unregistered users for external auth
  • User fields are case insensitive in bulk CSV
  • Redirect to provided origin after auth
  • Improve error messages if user cannot send PM emails
  • AdditionalOpts update and change to function
  • Show error messages when adding permalinks in the admin UI
  • Prevent UniqueViolation exceptions when syncing group mentions
  • Set the “hasTargetGroups” attribute in the composer when clicking the group message button.
  • Isolate modal and global key-binds
  • Bookmark topics were not being updated when the post moved
  • Allow dismissing Discard Drafts modal via ESC
  • Add all the keys that should be allowed in user_notifications
  • Replace ‘Chromebook’ with ‘Chrome OS’
  • Allow pasting invitees in invite modal
  • Composer save button should be :pencil: Save Edit when editing a PM post
  • Remove @discobot likes feature on public topics
  • uploads:fix_missing_s3 rake task used wrong SHA1
  • Delete orphan post revisions
  • Add topic_diff to PostRevisor
  • Make mobile back/forward keybinds work for anons
  • Error overriding user notification string with valid keys
  • New-topic route with sub-category and tags were broken
  • 404 error when editing an expanded reply
  • Rake db:validate_indexes was broken
  • Correct mailing list migration
  • Perform better email validation
  • Add migration to set correct redemption_count
  • Regression in colors used by non-default theme
  • Bulk “archive” and “move to inbox” for group messages was broken
  • Replace censored watched word consistently
  • Do not show duplicate_link notice for quotes
  • Never display the invite show page form if DiscourseConnect enabled
  • Don’t attempt to delete non-existent bookmark
  • Anons should see the Topic slow mode notice.
  • Ensures popper’s autocomplete instance is destroyed
  • Improvements to email styles
  • Ensures invisible link is not interfering with UI/tab order
  • Restore client.zh_TW.yml
  • A never created listener was removed
  • Tests were broken in Firefox
  • Clear draft modal correctly when switching topics
  • Ensure 100-logster initializer is run before 101-lograge
  • Only refresh the review count when the user can see the review queue.
  • Improve handling when email is obfuscated
  • Delete invalid web push subscriptions
  • Do not fail if Postgres is not available
  • All staff members (regardless of TL) should be able to pin/unpin topics
  • Browser-update should work with old browsers
  • Do not treat code tag as block level element
  • Delete post action from permanently deleted posts
  • Be able to handle long file extensions
  • In components, fall back to default theme color variables
  • Do not raise if post no longer exists
  • Viewing some tag routes wasn’t rendering the list without JS
  • Tests in admin/tests were not running
  • Fix narrative bot settings in multisites
  • Allow group owners manage group flair
  • Escape Font Awesome icons
  • Mention notification takes precedence over group
  • Correctly use invite to topic email templates
  • Do not convert format for site setting uploads
  • Deprecation warning - initialization autoloaded the constant
  • Move PWA App shortcut for bookmarks to new path
  • Allow additional valid theme .git url formats
  • Kernel.open is deprecated
  • Show a proper error message when trying to bulk award a disabled badge.
  • Show link in invite panel
  • Invite acceptance tests were broken in Ember CLI
  • Make sure tag-based topic list uses its own preload key
  • Do not block uploads path in robots.txt
  • When destroying a topic, destroy its associated published page.
  • Include json_schemer in prod
  • Nav items not recomputing on query param change
  • Add amazon sites to force_get_hosts
  • QUnit tests could time out based on load order
  • Update excerpt after process_post
  • Ensure the signup boolean is passed when started via _autoLogin
  • Bump aws-sdk-s3 and aws-sdk-sns
  • Do not add same email multiple times
  • Validate user email only once
  • Add translation string for clear all watched words
  • Do not clean up uploads when they’re used by theme settings
  • Incorrect parameter when using omniauth providers on invites page.
  • Race condition in draft sequence updates
  • New topic indicator on the mobile categories page
  • Subfolder prefix should work even if url starts with the prefix
  • Ensure UserField changes are reflected instantly in webhooks
  • Mobile app notification urls w/ subfolder
  • Make email a required param when accepting invite links.
  • Message bus when group private message
  • Missing quote in emoji cdn setting caused by 83f332b
  • Remap old S3 endpoints during backup restore
  • Typo in emoji path caused by 83f332b
  • Remove list double padding
  • Sort topic timer and bookmark time options
  • Check min tag count requirement when change category
  • Remove unused JS from “finish installation” page
  • Add href to user avatar in group cards
  • Topic#invite_group failed to notify users on newly created topic
  • Components mobile-specific CSS was missing
  • CSS tweaks so bookmark + timer modal work on mobile
  • Skip sending PM email for user silence
  • Add appropriate classes to html element including lang
  • 100% Width for logout button
  • Use addRawTemplates even when compiling .hbr files
  • Update digest when updating color definitions in theme component
  • Do not output empty style tags for components
  • Exclude users with posts from purge_unactivated query
  • When using Ember CLI theme Javascript/HTML was not being inserted
  • Incorrect URL for tag pages inside category in subfolder setup.
  • Reintroduce auto_silence_first_post_regex
  • Don’t display error if only error is a missing image
  • Ignore enter key press on “move to existing post” search field
  • Send notification in user’s locale if available.
  • Allow adding user to PM when inviter is in allowed list (even
  • Strip whitespace from URL before validating
  • Login modal max-width wasn’t specific enough
  • Paste table with multiline cell
  • Detect installed themes using URLs instead of names
  • Unsubscribe from topic presence when navigating between topics
  • Pass ajax function to loadOneboxes
  • Ensure badge description is updated when routing without loading state
  • Allow entering blank values in relative-time-picker
  • Improve error message when login_required sites are under load
  • Emails.rake-use domain when sending mail test
  • Don’t update posts_read_count when the post is from a PM.
  • Log warning when context is missing when a user is destroyed
  • Allow mobile-nav to work without loading transitions
  • Adding a custom scope should not modify the original ones.
  • Avoid Safari service worker error on back navigation
  • Don’t show “bulk” icon on group-index for unauthorized users
  • Do not send rejection emails to auto-deleted reviewable users
  • Make email_valid handling consistent
  • Close navigation dropdown when item selected
  • Reduce the time_read threshold to one minute.
  • Subfolder replace should only affect URL prefix
  • Sort admin dashboard new updates by latest
  • Don’t require a rejection reason if the user is a spammer.
  • Do not allow bookmarks to use post date in past for reminder
  • Ensure corrected migration runs
  • Optimise MoveNewSinceToTable
  • Use the S3 CDN for the Group flair
  • NewPostManager should respect category_group_moderator settings
  • Limit post read time to the max integer value
  • Remove top gradient from signup modal
  • Delete topic timers far in the future
  • Remove unnecessary OR from dismiss service
  • Bump max topic timer duration to 20 years
  • Dismiss new when topic_user exists without last read
  • Allow plugins to correctly extend API key scopes.
  • Hide sso payload behind a button click and log views
  • Auto close topic from category settings based on topic created_at
  • Force refresh staff action logs when transitioning from site settings
  • Category redirect to correct slug should not loop
  • Fix subcategory, tag drops and none values
  • Update topic_count when updating visibility
  • Use autocomplete=discourse in select-kit to disable autocomplete in Chrome
  • False for service workers to stop log spam via workbox
  • Do not mark group_flair images as secure on upload
  • Clean up topic-timer-info CSS classes, add edit button, and improve UI
  • Adds google tracking to page publishing
  • Restoring backup via UI was broken
  • Do not show SSO last payload to moderators
  • Dismiss new with better migration
  • Should_alter_quality should respect png_to_jpg_quality
  • Regression in admin new features
  • Allow all tags in site/theme settings, ignore tag group restrictions
  • Validate duration minutes values for topic timer
  • Optimize move to dismiss_new_topics migration
  • Adjust width to avoid horizontal overflow
  • Don’t add a slug to constructed quote urls
  • When adding a quote when the composer is closed, add a newline
  • Handle empty email address from authentication provider
  • Login UI Fixes
  • Do not notify when the hidden tag is added or removed
  • Restoring could fail due to missing path
  • Restoring backup could fail due to missing uploads
  • Return 404 not found error if a topic is deleted.
  • Check if post.topic exists before publishing topic updates
  • Some error messages used wrong translation key
  • Correct server error for starting SSO login, and add spec
  • Topic progress bar should be on the left in RTL layouts
  • Topic timer duration_minutes was not backfilled correctly
  • The invite success email translation variable was renamed
  • Select earliest post when aggregating posts in a topic for search.
  • Don’t cancel filtering on second “n replies” tap
  • Improve SCSS handling in components
  • Process new invites when existing users are already group members
  • Save updated remote theme, only update enabled themes/components
  • Composer upload icon regression because of WEBP
  • Don’t create email invites when SSO is on or local logins are off
  • Don’t invite new users via group with SSO on or local logins off
  • In FastImage 2.2.2 an error is raised with a nil path
  • Include extra SCSS in child theme
  • Restore support for pasting multiple PM recipients
  • Avoid pulling hotlinked images of post that have been deleted.
  • Refresh category order after save
  • Ensures rects is present before using it
  • Show bookmark name in quick access hover
  • Make discobot certificate faster/non blocking
  • Skip shared drafts logic if disabled
  • Emoji search/autocomplete should respect selected skin tone
  • Existing shared drafts should be accessible
  • Return the CDN’s URL when using the site’s small logo as the system’s user avatar.
  • Stop trying to set values on destroyed bookmark component
  • IMAP allow unknown senders to reply to group topics via email
  • Invisible is not the opposite of visible
  • Approving a user was not sending an email
  • Allow a single invite per email address
  • Translated button title didn’t work
  • Do not cache translated trust level names in site settings
  • External auth account creation in iOS app
  • Ensure ‘tr’ is called on a string.
  • Can’t remove selection from group chooser in tag group settings
  • Restore user summary’s delete button behavior.
  • Polls extending in post reply histories
  • Move post_search_data migration into onceoff job
  • Support version in new feature payload
  • “Customize text” link was broken on badges admin page
  • Only de-prioritise exact matches in mentions
  • Un-prioritise inactive users in user search
  • Destroy associated user api keys when making a user anonymous.
  • Cleanup authentication_data cookie after login
  • Dismissing unread topics with a tag
  • Ensures timeline_lookup includes last tuple
  • Reindex_search job should work on model with no search data
  • Remove rendering UX from bookmark model
  • Cannot find currentThemeColorSchemeId when no themeId is present
  • Check the confirmation result before deleting SSO record
  • Remove scheduled DND timings when schedule is disabed
  • It seems sometimes shims are evaluated by older JS engines
  • Print raw html of logo image to skip unwanted html encoding
  • Update categories without full page refresh
  • Broken URL when username contains subfolder.
  • Share popup is positioned incorrectly in RTL locales
  • Embedded comments should only return regular posts
  • Show the fallback locale warning when both settings are enabled.
  • Change default for IncomingEmail#created_via to 0 (unknown) and make NOT NULL
  • I18n couldn’t find translations.
  • Allow max_redemptions_limit to be 1
  • Polish lang label
  • Don’t try to focus on a missing element
  • Support for single use invite links
  • Always show overriden colors filter
  • Remove rendering UX from ember models
  • Unescape emoji when pg headlines is used for search result blurb.
  • Do not email group user with user_private_message notification
  • Make sure login required skipped for confirm new email routes
  • CurrentUser was missing appEvents
  • Add Retry-Header to rate limited responses
  • Do not test bookmark rate limiter message
  • Do not process pop3 mails > 1 week old
  • Add bookmark limits
  • Check for user presence before granting badge
  • Allow users to opt-out of using the site’s small logo as the system user avatar.
  • Acceptance/bookmarks test date issue
  • Make sure current user timezone is used for bookmark reminders from post dates
  • Remove migrate_from_s3 task that silently corrupts data
  • TopicTrackingState was initialized after Site
  • Url:refresh triggered when query params change
  • Stop incorrect emailing of group email from PostAlerter
  • Prevent users from converting the default theme to a component
  • IMAP post alerter race condition and code improvements
  • Render fancy title correctly in composer
  • Render topic fancy title in review queue
  • Make category change work with shared drafts
  • Prevents debouncing and query to override each other
  • Use ImageMagick to detect animated images
  • Safari iOS page title and url regression when sharing
  • Users can remove themselves from a PM even if they can still access it through a group.
  • Use the same time moment for related Redis calls in rate limiter
  • Sliding window end time in rate limiter
  • Make category slugs lowercase
  • Do not downsize or crop GIF images
  • Discobot exception when site_contact_username is promoted
  • Publish DND ends_at updates in httpdate format
  • Hiding a post should not trigger the duplicate check
  • Show unassigned component warning when installing multiple components successively
  • Reset theme install modal state on close
  • Hidden tags returned in extras of tags index json
  • Always truncate uncomplete emojis in excerpts
  • Broken emojis in topic excerpt
  • Do not include URL query in auto-generated CSP header
  • Don’t error topic RSS when posts are deleted
  • Don’t count HTML comments when calculating reply length.
  • Tab key should autocomplete like enter key does
  • Recurring was not working for some cases (eg: hours and unit > 1)
  • Fix bg color of header on published page
  • Hide notification count on document title in Do Not Disturb
  • Validate type when picking an avatar.
  • Group SMTP email improvements
  • Inline Onebox should use encoding from Content-Type header when present
  • Prevents autocompoete of username to appear on right
  • Ensures defined expired_in is passed from write to write_entry
  • Correctly set scroll position when viewing a tag’s topic list.
  • Increase inventory lag for s3 to 2 days
  • Ensures recurring works when setting a start date in future
  • S3 CDN warning was showing wrong warning message
  • The title attribute of the diversity scales was incorrect
  • When the user is deleted anonymise category post
  • Show all topic statuses on full page search.
  • Use Redis replica host and port
  • Allow for final sigma in suggested usernames
  • Don’t enqueue imported users when there’re multiple custom fields.
  • Disallow zero-width and other non-printing characters in tags
  • Handle badge grant for deleted badge
  • Search topic title headline being truncated.
  • Missing PG topic title headline when pg headlines is enabled.
  • Autoplay videos must always be muted
  • Show restricted tags in bulk select
  • Re-run remove flag and queued post web hook migrations.
  • Make find_by_slug_path work with default slugs
  • Clear in-process theme cache after clearing DB cache
  • Missing default notification level on group creation
  • Scroll to the last position when navigating back to the tag topic list.
  • Bypass AnonymousCache for /srv/status route.
  • No email when the category is muted and mailing list is on
  • Do not forbid tags in /new-topic on mobile
  • Clear WordWatcher cache after topic_spec
  • Show quote replies when filtering
  • Show correct avatar in post stream bar
  • Users without shared drafts access can still have access to the category.
  • Make Oneboxer#apply insert block Oneboxes correctly
  • Show retina avatars on Chrome
  • Posts with Staff Colors were excluded from the group activity
  • Show ‘New’ filter when ‘none’ subcategory set
  • Normalize links by converting them to lower case
  • Build correct topic list filter
  • Logout redirect should only be /login for login_required sites
  • Use sql_fragment instead of sanitize_sql_array
  • notify_file_change was outputting a command to vim
  • Correct tracking when mute all categories
  • Don’t raise an error if a custom emoji image was deleted
  • Only block local edits for git-sourced themes
  • Prevent error when primary email is missing
  • Only cache reports with exceptions for 1 minute
  • Prevent usage of composer-action-undefined CSS class
  • Replace Vimeo iframes with a link in emails
  • Avoid clock skew issues when logging in with Google
  • Allow for cateogry edit routes of unknown depth
  • Remove custom ‘error’ action on build-category-route/discovery
  • Actually error when topic timer time is in the past
  • Removes extra slashes from URL
  • Generate correct prev and next topics page URL
  • Correct casing of whitelisted SVG elements
  • Restore dismissing the first notification
  • Local dates showed incorrect timezones with extra whitespace
  • Follow open in new tab site setting for bio links
  • Stop category 404s from breaking the router
  • Hide user id when hide_email_address_taken
  • Adjust reviewable menu placement on mobile
  • Include locale in cache key for not_found_topics
  • Use CDN for custom emojis
  • Group#flair_url must be a real URL
  • Do not replace smiling_face by slight_smile
  • Trigger an event when a post is bookmarked.
  • Stop using duplicate composer button ID
  • Correct link in the notification about moved post
  • Load .js files from plugins in qunit testing env
  • On invite redemption only update pending ReviewableUser record
  • URL encode tag name
  • Show/hide ignored users preferences
  • Don’t error-index category job when missing category
UX CHANGES
  • Return correct error message if reviewable user is deleted already.
  • Improve category controls on smallest devices
  • Admin watched words UI tweaks
  • Update copy on the notifications empty panel
  • Allow saving with cmd+s/ctrl+s with Ace editor
  • Hide the list of file extensions on the upload dialog
  • Add CSS classes on body tag based on topic statuses.
  • Anticipate anchor link hover
  • Refactor security modals
  • Reduce the number of columns on invite page
  • Fix styling for long label in multi-select choices
  • Minor tweaks to insert-hyplink modal
  • Ensures toolbar gear button has identic color and height
  • The Site’s logo is the selected option when changing the system’s user avatar.
  • Fix positioning of back button on progress bar
  • Consistent topic timer message button order
  • Mobile consistency for topic status messages
  • Improve alignment and spacing of category headers
  • Correctly shows outline around focused input time
  • Improve copy when no results in bookmarks and notifications quick access panel
  • Stop presence indicator hop, space consistency
  • Do not pre-select blank tag on append tags bulk action
  • Uses native date picker when possible (eg: not safari)
  • Prevent topic progress bar from overlapping
  • Fix layout of group header buttons on mobile
  • Fix focus style for post edit history button
  • Update positioning of mobile post controls
  • Improve user card control layout for long text
  • Wider drop down for top page select kit
  • Update signup cta styles
  • Show error message instead of disabling save button on tag groups page
  • Displays a descriptive error when theme is not allowed
  • Smoother timeline footer animation, padding fix
  • Mobile styling for discard draft modal buttons
  • Prevent some composer buttons from receiving focus
  • Full height composer on mobile Android
  • Minor styling improvements to invites
  • Moves from summary/details to a button to expand github body
  • Improve poll builder UI
  • Adds styling for new github PR body details/summary
  • Shows a hint when there are more tags than displayed
  • Always display remove emoji btn from emoji-value-list
  • Icon instead of text for hiding mobile preview
  • Better position for search bulk select button
  • Move logs/watched_words to customize/watched_words in admin section
  • More consistent user control button width
  • Remove reference to contact form in settings
  • Login modal adjustments
  • Fix tab list alignment in emoji popup
  • Let users know they disabled discobot and they can’t interact with it.
  • Emoji popup layout adjustments
  • Display a tooltip when trying to delete an automatic group.
  • Make sure staff logs don’t break the layout
  • Rename button with a duplicated name.
  • Composer actions menu header should display the icon of selected action
  • Show first unique letters in invite link
  • Improve topic footer alignment and layout
  • Move modal footer into better container
  • Add image uploader widget for uploading badge images
  • Reduce opacity of code copy button
  • Show Topic column in invites pending tab
  • Show the Dismiss New button at the top of the topics.
  • Add class to body on first unread notification
  • Respect “prioritize username in ux” setting wherever possible
  • Add bell emoji for better unread education
  • Pasting a twitter link into composer title will not set the title
  • Consistent labels in invite form
  • Fix broken styling on login modal when local login is disabled.
  • Login; smaller titles, more consistent spacing, other fixes
  • Minor improvements to invites
  • Remove duplicate title from watched words page
  • Add class to email div on login
  • Fix bulk select button height on search page
  • Clean up tag styles to improve alignment
  • Restore autofocus on login inputs
  • Add link for email login below username, remove button
  • Remove redundant focus style
  • Use default browser focus styling for checkbox and radio inputs
  • Styling adjustments for admin new features
  • Allow select-kit to have an autofocus option
  • More consistent group mention style
  • Remove emoji step in wizard
  • Tweak group layout to fix button alignment
  • Skip github commit avatars for topic/post thumbnails
  • Make tag input full width for PMs
  • Implements a new tags-intersection-chooser
  • On very short screens switch quick-access-profile to 2-columns
  • Show bullets for some composer lists
  • Adjust padding on create account modal
  • Publishes page, on public change, only when page is published
  • Remove margin from security key login button
  • Change emailLogin to info class when empty
  • Adjustments to admin theme editor
  • Add editing guidance for remote themes
  • Fix excess line breaks in login modal alerts
  • Relative-time-picker should use pluralized strings
  • Fix local-dates styling
  • When auto-selecting topic make sure the focus is on selected topic
  • Second Factor + Alert Display
  • Show plugin descriptions on admin plugins page
  • Trim @ char from start of the username string in search.
  • Remove pluralization in single category notification types.
  • Specify social button styling
  • Prevent badges on usercards from overflowing
  • Improve tag and assign display in search
  • Adjust focus styles for autocomplete input
  • Hide external login column when account creation in progress
  • Adjust gradient, icon hover, capitalizations
  • Remove Convert option for system themes
  • Changes to new features section in admin dashboard
  • Remove 2px border from some select-kit buttons
  • Remove Helvetica from our font stack
  • Small fix for Chrome focus style on replies button
  • Show caret icon on user notification dropdown
  • Don’t display tag notification menu on category page.
  • Fix reply where modal layout
  • Clarify user rejection modal
  • Fix & clarify bulk notification change modal
  • Use bright color for primary button hover on dark schemes
  • Adjust focus styles for topic post menu, composer cancel
  • Popup menu buttons need focus style
  • Add a confirmation modal to “Remove All Tags” action
  • Remove unneeded margin from user stream
  • Fix button alignment on log-in required page
  • Ensure category breadcrumbs have consistent height
  • Uniformize styles for focus states
  • Always show confirmation dialog when converting themes/components
  • Remove border from certificate due to iframe
  • Allow some overflow in composer preview
  • Fix bulk select top positioning
  • Make desktop category page topics match mobile
  • Small tweak to category delete warning
  • Respect email_editable site setting in user activation page.
  • Simplify narrative bot bio
  • Makes the theme editor display placeholder correctly for RTL languages
  • Show onebox error preview image as favicon
  • Specify width and height for onebox preview error image
  • Warn about messages to be orphaned while deleting a group.
  • Make moment.js produce Arabic numerals instead of Hindi numerals in the Arabic locale
  • Fallback locale warning improvements.
  • Use uniform style for tag counts
  • Text customization for different languages.
  • Show a warning on the category edit page when category style is none and colors are disabled.
  • Stop attempts to convert the default theme to a component by removing button
  • Ellipsis hamburger menu link text when overflowing
  • Add space between links and text in labels
  • Remove extra word from approval_not_required client string
  • Improve color scheme choices in user prefs
  • Refactor topic list nav
  • Autocomplete suggestions should be unselected by default
  • Allow quick access profile content to scroll
  • Allows to copy/paste a list of | separated values in sk
  • Transition to edit URL when adding a category
  • Move do not disturb to profile panel
  • Text overflow user-{primary,secondary}-navigation
  • Move reply filter button on mobile
  • Adjust default menu width
  • Blend header colors
  • Don’t wrap menu text under icon
  • Add title attribute to watched word input
  • Make theme install modal more responsive
  • When input placeholders are too long, truncate with ellipsis
  • Remove timeline from print view, fix header in crawler view
  • Tweaks to filtered replies
  • Show required indication consistently on signup
  • Fix unreachable buttons on menus in Safari iOS
  • Add full date title to fps-result date
  • Category Onebox styling changes
  • Makes sk components full width on users admin page
  • When requiring user fields at signup, also mark default fields as required
  • Fix invite checkbox width issue
SECURITY CHANGES
  • Bump Rails to 6.1.3.2
  • Improve theme git import
  • Fix is_private_ip for RateLimiter to cover all cases
  • Prefer Loofah for processing cooked HTML
  • Attach DiscourseConnect (SSO) nonce to current session
  • Rate limit MFA by login if possible
PERFORMANCE
  • Preload JsLocaleHelper.load_translations for default locale.
  • Preload LetterAvatar.image_magick_version in master process.
  • Ensure locales are always handled as symbols internally
  • Make stylesheet max_file_mtime calculation more efficient
  • Add timeout to theme import git commands
  • Improve theme stylesheet compilation performance
  • Remove N+1s from ThemeController#update and #show
  • Properly preload emails to speed up user exports
  • Async notify users after inviting group
  • Improve category moderators query
  • Avoid regex on uploads table
  • Avoid lookbehinds when replacing links in imported emails
  • Batch expensive post-migration
  • Migrate search data after locale rename
  • Improve cook_url performance for topic thumbnails
  • Optimize homepage and topic performance
  • Add indexes to speed up profile pages
  • Run user merging task in a background job.
ACCESSIBILITY
  • Category logos are decorative, set empty alt
  • Makes replies count a button and not a link
  • Make th keyboard accessible + aria attribs
  • Do not use positive tabindex in composer
  • Makes search results count readable by screen reader
  • Improves avatar menu focus/active states
  • Associates lists with labels on interface page
  • Links change username input to its label
  • Switch tabs using the keyboard
  • Improve the header menu “view all” title.
  • Deselect focused choice when using enter in multi-select
  • Gives autocomplete in search a more accessible name
  • Makes other and color, fieldset/legend elements
  • Makes edit username and avatar accessible
  • Ensures avatar image in site header has alt attribute
  • Add rowheader to topic title TDs
  • Makes select-kit header a listbox
  • Adds support for aria-current through d-navigation-item
  • Makes aria-owns an ID and not a data attribute
  • Sets has-popup as menu for select-kit components
  • Makes quote controls accessible
  • Sets the html lang to user’s locale when possible
  • Correctly sets a name on combo-boxes for single selects
  • Adds support for aria-expanded and aria-controls to btn
  • Makes user notifications list more accessible
  • Hamburger menu aria-{expanded,haspopup} and user title
  • Correctly sets role=dialog and aria-labelledby for d-modals
  • Uses role=button and supports ariaPressed for tapTile
  • Structure user menu as tabs.
  • Makes post-edits-indicator a button instead of a link
  • Improves search-in-options filter accessibility
  • Makes advanced search and html heading
  • Associate search controls with their labels
  • Add aria-label to input clear button
  • Update selected name role to button
  • Improve the quick access menu accessibility.
  • Accessible user menu icons
  • Add aria-labels to search inputs and search button
