إصدار Discourse في community.gasturbinesupport.com: غير موجود
What I’ve Done:
I have set up a 2 GB droplet on DigitalOcean, have forwarded the domain to digitalocean using the nameservers, have added an A record in digitalocean for the subdomain, and installed the oneclick version of discourse on the droplet.
I have set up the mailgun server and tested it using discourse-doctor and it delivers the email as expected.
The Problem
Nothing comes up when I search the subdomain. When I ran the discourse-doctor from /var/discourse, this comes up:
Discourse version at community.gasturbinesupport.com: NOT FOUND
Discourse version at localhost: NOT FOUND
Possibilities:
There is another user with a similiar problem here. His problem had to do with the ssl cert but I’m not sure how to disable the SSL .
Thanks for helping.
إعجاب واحد (1)
Unfortunately this is an unsupported install method.
Please use our discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub to reinstall.
6 إعجابات
Thank you for the quick reply. I destroyed that droplet and created a new one. Went through the whole setup manually as detailed in the guide. Now when I run discourse-doctor it shows discourse version at community.gasturbinesupport.com: discourse 2.4.0.Beta10 and discourse version at localhost: discourse 2.4.0.beta10.
However, When I actually go to the link, it throws an error: this site cant be reached. The connection was reset.
What are my next steps in diagnosing the problem?
Thanks for the help.
إعجاب واحد (1)
It’s loading fine for me… Seems like a DNS issue at your end, maybe wait a couple hours then retry the link?
4 إعجابات
Thank you so much. Really appreciate it.
3 إعجابات
