Modereert een categoriebeheerder ook automatisch subcategorieën?
Hi there,
Just a question about this feature, can said group also moderate subcategories within the parent category, or are they only able to moderator the parent category itself?
Also is there any plan to enable a specific user to be a category moderator?
Thanks :smile:
For that, you would need to add the group to the subcategory moderation settings, as well as the parent category.
You could set up a group with only one person in, and that would do it. :+1:
