Docker build interrotto - sito non disponibile
I, [2023-01-17T16:40:30.885959 #1]  INFO -- : configurazione web completata
I, [2023-01-17T16:40:30.886580 #1]  INFO -- : \u003e cd /var/www/discourse \u0026\u0026 gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,\"\"); print $0 }' Gemfile.lock)
ERRORE:  Caricamento comando: install (RuntimeError)
	impossibile ottenere urandom
	/usr/local/lib/ruby/3.1.0/securerandom.rb:75:in `urandom'
	/usr/local/lib/ruby/3.1.0/securerandom.rb:75:in `singleton class'
	/usr/local/lib/ruby/3.1.0/securerandom.rb:42:in `\u003cmodule:SecureRandom\u003e'
	/usr/local/lib/ruby/3.1.0/securerandom.rb:41:in `\u003ctop (required)\u003e'
	\u003cinternal:/usr/local/lib/ruby/3.1.0/rubygems/core_ext/kernel_require.rb\u003e:85:in `require'
	/usr/local/lib/ruby/3.1.0/resolv.rb:8:in `\u003ctop (required)\u003e'
	/usr/local/lib/ruby/3.1.0/net/http.rb:25:in `\u003ctop (required)\u003e'
	/usr/local/lib/ruby/3.1.0/rubygems/request.rb:2:in `\u003ctop (required)\u003e'
	/usr/local/lib/ruby/3.1.0/rubygems/remote_fetcher.rb:3:in `require_relative'
	/usr/local/lib/ruby/3.1.0/rubygems/remote_fetcher.rb:3:in `\u003ctop (required)\u003e'
	/usr/local/lib/ruby/3.1.0/rubygems/spec_fetcher.rb:2:in `require_relative'
	/usr/local/lib/ruby/3.1.0/rubygems/spec_fetcher.rb:2:in `\u003ctop (required)\u003e'
	/usr/local/lib/ruby/3.1.0/rubygems/dependency_installer.rb:6:in `require_relative'
	/usr/local/lib/ruby/3.1.0/rubygems/dependency_installer.rb:6:in `\u003ctop (required)\u003e'
	/usr/local/lib/ruby/3.1.0/rubygems/commands/install_command.rb:4:in `require_relative'
	/usr/local/lib/ruby/3.1.0/rubygems/commands/install_command.rb:4:in `\u003ctop (required)\u003e'
	/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:228:in `load_and_instantiate'
	/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:135:in `[]'
	/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:201:in `find_command'
	/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:183:in `process_args'
	/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:149:in `run'
	/usr/local/lib/ruby/3.1.0/rubygems/gem_runner.rb:51:in `run'
	/usr/local/bin/gem:21:in `\u003cmain\u003e'
ERRORE:  Durante l'esecuzione di gem ... (NoMethodError)
    undefined method `deprecated?' for nil:NilClass
      cmd.deprecation_warning if cmd.deprecated?
Per favore, condividi i log completi della ricompilazione e la tua app.yml
Sembra simile al recente e anche irrisolto
“undefined method `deprecated?’ for nil:NilClass” on rebuild
Quindi dovrebbe essere lo stesso problema. Qual è la tua distro e versione del kernel @jaswinder?
Ho avuto un problema molto simile oggi, con piĂą rebuild falliti e un errore molto simile.
Ho eseguito un ./launcher cleanup manuale e poi un git pull - questo ha magicamente risolto il problema e il rebuild è proseguito senza problemi dopo.
Sono stato contento di avere un’installazione a 2 container in modo da poterla abbandonare e tornarci quando volevo!!
(Il kernel è 5.4.0-126-generic su Ubuntu 20.04.5 LTS)
