If during an upgrade I check the progress of said upgrade via the API, I get null progress (logs and percentage) even though the UI shows progress.
The command I’m running is this:
curl -X GET "https://example.com/admin/docker/progress" -H "Content-Type: multipart/form-data;" -d "path=all" -d "api_key=1234" -d "api_username=system"
In the beginning of the upgrade, the output I get looks like this:
{"progress":{"logs":"********************************************************\n*** Please be patient, next steps might take a while ***\n********************************************************\nCycling Unicorn, to free up memory\nRestarting unicorn pid:... 386\n","percentage":"10"}}
In the middle of the upgrade, the output looks like this:
{"progress":{"logs":null,"percentage":null}}
I believe the progress goes to null right when the job queue is stopped. The admin UI still shows lots of progress (the below log is from the UI), but the progress via API remains at null.
Stopping job queue to reclaim memory, master pid is 386
$ cd /var/www/discourse && git fetch --tags && git reset --hard HEAD@{upstream}
From https://github.com/discourse/discourse
- [tag update] latest-release -> latest-release
HEAD is now at 6525613 PERF: Use joins for `Post.for_mailing_list` instead of `NOT IN`.
$ cd /var/www/discourse/plugins/discourse-custom-wizard && git fetch --tags && git reset --hard HEAD@{upstream}
HEAD is now at e127d0c Merge pull request #7 from procourse/fix_footer_logo
Any ideas what’s going on?
