L'incorporamento di commenti in un altro sito non supporta URL sensibili alle maiuscole
Embedding Discourse comments in another site does not support case-sensitive URLs.
Using the standard embedding instructions provided in the admin interface, under Customize > Embedding, the host site provides the discourseEmbedURL value. If providing case-sensitive URL paths, such as http://site.com/AAA and http://site.com/aaa, the same comment thread will be embedded in both pages.
The root of this issue is in the normalizeURL function in Discourse’s public/javascript/embed.js file, which currently reads:
function normalizeUrl(url) {
    return url.toLowerCase().replace(/^https?(\:\/\/)?/, '');
I would argue there is no reason to lower case the URL provided. The URL is provided by the host application, which should be able to make decisions about what is considered a unique URL. Removing toLowerCase() should be a non-breaking change that will allow case-sensitive URLs to be supported properly.
    return url.replace(/^https?(\:\/\/)?/, '');
Thoughts?
3 Mi Piace
I think that it’s confusing to people to have URLs that are case sensitive so it makes sense to downcase them.
1 Mi Piace
No, one should never assume that URL paths are case insensitive.
I suspect this was done because we had people having trouble embedding without the toLowerCase, @techAPJ?
@agiletortoise I presume you are raising this because this is actually causing a problem for you somewhere?
5 Mi Piace
Yes, it is. I have case-sensitive identifiers in the URLs in the action directory site I run for my app (example).
In retrospect, I should probably not have used case-senstive IDs, but that’s water under the bridge - would be hard to change now. Used a generator similar to those used for URLs shorteners like bitly (which are also case-sensitive).
I’d agree this could be a problem if it were a case that the user had to enter these URLs, but since the embedding is done programmatically, it doesn’t seem necessary to downcast.
4 Mi Piace
eh, URL paths MUST be treated as case sensitive by external systems… just like email usernames, but that’s a story for another time
5 Mi Piace
The W3 standards say that except for machine names URLs should be case sensitive. While it may be confusing I think it makes most sense to adhere to the standards out there.
https://www.w3.org/TR/WD-html40-970708/htmlweb.html
1 Mi Piace
Yeah. I’m generally a hard-liner when it comes to case-sensitive filenames. I’ve been indignant about operating systems that lazily ignore case in filenames and cause people to do stupid stuff for at almost three decades (or at least since about 1995 when I started developing web apps and the stupid Mac had a case-insensitive file system). I’m not sure what happened. It was at 9:43 AM, so I should have been wide awake and even had coffee. Maybe someone hacked my account and wrote that? :wink:
But now it’s been too long for me to delete the post to remove the record of this.
It looks like this is one of those situations where one user previously had issues due to it being case insensitive, and now the opposite! What a fun world software development is!
@techAPJ I hate to do this, but could you revert the case insensitive part? It is technically allowed and I think we should stick to the standards here now.
9 Mi Piace
Okay, I reverted that commit.
8 Mi Piace
