I’m trying to run the sentiment backfill rake, it starts working for a while (say about 6-10 minutes) and then it throws an error.
:/var/www/discourse# rake ai:sentiment:backfill --trace
** Invoke ai:sentiment:backfill (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute ai:sentiment:backfill
............................................................rake aborted!
Net::HTTPBadResponse: Net::HTTPBadResponse (Net::HTTPBadResponse)
/var/www/discourse/plugins/discourse-ai/lib/inference/discourse_classifier.rb:14:in `perform!'
/var/www/discourse/plugins/discourse-ai/lib/sentiment/sentiment_classification.rb:42:in `request_with'
/var/www/discourse/plugins/discourse-ai/lib/sentiment/sentiment_classification.rb:34:in `block in request'
/var/www/discourse/plugins/discourse-ai/lib/sentiment/sentiment_classification.rb:33:in `each'
/var/www/discourse/plugins/discourse-ai/lib/sentiment/sentiment_classification.rb:33:in `reduce'
/var/www/discourse/plugins/discourse-ai/lib/sentiment/sentiment_classification.rb:33:in `request'
/var/www/discourse/plugins/discourse-ai/lib/classificator.rb:13:in `classify!'
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/sentiment/backfill.rake:21:in `block (2 levels) in <main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:71:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:71:in `block in find_each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:138:in `block in find_in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:245:in `block in in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:229:in `loop'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:229:in `in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:137:in `find_in_batches'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/relation/batches.rb:70:in `find_each'
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/sentiment/backfill.rake:17:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:199:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:182:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:147:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:132:in `top_level'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:208:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli.rb:451:in `exec'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor.rb:527:in `dispatch'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli.rb:34:in `dispatch'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli.rb:28:in `start'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/exe/bundle:28:in `block in <top (required)>'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/exe/bundle:20:in `<top (required)>'
Tasks: TOP => ai:sentiment:backfill
If I try to run it again, it aborts immediately with the same error, i.e. no incremental processing. Looks like it reached some point in the process where now it’s encountering this error.
Do you need any additional logs?
