Erreur après avoir redémarré le discourse
Tell me, what could be the error?
After the restart, the discourse stopped running.
Logs can be seen by reference https://pastebin.com/DzUPNhAT
Remove the discourse-rss-poster plugin and try again.
He’s getting throttled by Rubygems. Where are you hosted?
Thanks huge for the help, after removal of a plug-in discourse-rss-poster, discourse has successfully restarted. @LeoMcA what can be problematic with your plugin? You can view?
If you read the errors, you’re being throttled by rubygems. So your issue wasn’t that plugin per se, but that you got throttled.
Tell me, how can I fix this?
Well, you can wait 24 hours and try re-enabling the plugin and doing another rebuild, maybe by then rubygems might not be throttling you (though to be honest, I’m not sure I see it as a throttling issue, considering the error happens between two rubygem downloads/installs… that or I’m reading the output wrong).
The issue is that your ip block is likely hammering the rubygems server…the solution is likely to use something like DigitalOcean, I rarely have this issue. Something is weird but this is not a discourse issue, you should contact rubygems – you can read more about it here. I never actually saw this issue. I use Rackspace for the discourse instance I maintain…I’d bet money this is an AWS issue.
Tried to plugin the plugin discourse-rss-poster , but the same error
https://pastebin.com/H8dSU9CF
You are being throttled due to hitting the rate limit by rubygems. I repeat: this is not a discourse issue.
Look at line 639 onwards in your paste and read it ;).
One other thing you could do: install another plugin in place of discourse-rss-poster – does that cause you to hit the rate limit as well? I suspect it will.
Are you using a plain Ubuntu AMI, or did you take a prebuilt one from the marketplace?
Last week someone was having similar problems with an Intuz pre-built AMI - the issues went away when they moved to a plain Ubuntu 16 AMI and migrated their instance. See here:
https://meta.discourse.org/t/upgrade-error-on-aws-free-tier-t2-micro/63756
And why if I disabled the plug-in “discourse-rss-poster” then everything works.
But is it worth it to include, then download discourse fails?
Updated the discourse to the latest version, when the plug-in is activated, the discourse never starts. Is this problem in the discourse-rss-poster plug-in?
@11145 – where is this hosted?
Answered in a personal
