Fehler: Bootstrapping fehlgeschlagen
Hallo. Ich wollte das Plugin installieren, aber nach /rebuild app erhielt ich einen OutOfMemory-Fehler.
Ich habe Speicherplatz hinzugefügt, den Server neu gestartet und /rebuild app wiederholt, aber diesmal verstehe ich das Problem nicht:
(Vollständige Trace durch Ausführen der Aufgabe mit --trace anzeigen)
I, [2024-03-08T19:22:34.066685 #1]  INFO -- : gem install ruby-openid -v 2.9.2 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openid-2.9.2
1 gem installed
gem install rack-openid -v 1.4.2 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed rack-openid-1.4.2
1 gem installed
gem install omniauth-openid -v 2.0.1 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-openid-2.0.1
1 gem installed
gem install omniauth-steam -v 1.0.6 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-steam-1.0.6
1 gem installed
gem install omniauth-vkontakte -v 1.7.1 -i /var/www/discourse/plugins/discourse-vk-auth/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-vkontakte-1.7.1
1 gem installed
I, [2024-03-08T19:22:34.067577 #1]  INFO -- : Terminating async processes
I, [2024-03-08T19:22:34.067648 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2024-03-08T19:22:34.067687 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 111
2024-03-08 19:22:34.068 UTC [42] LOG:  received fast shutdown request
111:signal-handler (1709925754) Received SIGTERM scheduling shutdown...
2024-03-08 19:22:34.072 UTC [42] LOG:  aborting any active transactions
2024-03-08 19:22:34.078 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-03-08 19:22:34.078 UTC [46] LOG:  shutting down
2024-03-08 19:22:34.109 UTC [42] LOG:  database system is shut down
111:M 08 Mar 2024 19:22:34.117 # User requested shutdown...
111:M 08 Mar 2024 19:22:34.118 * Saving the final RDB snapshot before exiting.
111:M 08 Mar 2024 19:22:34.288 * DB saved on disk
111:M 08 Mar 2024 19:22:34.290 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse &amp;&amp; su discourse -c 'bundle exec rake db:migrate' failed with return #&lt;Process::Status: pid 3378 exit 1&gt;
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
962ee73e2d4c8f902da810010d0bb70d5a784416d3b1ab80bcad7c4ff1351149
root@cv3533865:/var/discourse#
Könnten Sie ein paar Zeilen mehr darüber bereitstellen? Der Fehler scheint ein paar Zeilen abgeschnitten zu sein.
Okay, ein paar Minuten. Arzt begonnen
Vergessen. Das Problem lag am Plugin, das ich installieren wollte: GitHub - Gonerdot/hello_plugin
Ich habe ein einfaches Plugin mit ChatGPT geschrieben, da ich Ruby selbst nicht verstehe, aber anscheinend ist etwas schiefgelaufen.
Ich kenne Ruby nicht, aber das sieht fast so aus, als wäre es besser als Customization > Theme component anstatt als Customization > Plugin.
Ja. Es kann eine Themenkomponente sein. Sie benötigen nur ein Plugin, um Dinge auf der Ruby-Seite zu ändern. Werfen Sie einen Blick auf den Theme Developer Quick Reference Guide und den Einstiegsleitfaden.
