Error in logs related to twitter_login
RBoy reported an error in the logs after updating to Discourse 3.6.0 beta 2, related to the twitter_login problem check, despite Twitter (X) signup and login functioning normally. The error was caused by a breaking change in the Faraday gem. ted acknowledged the issue and confirmed a fix was merged. After updating to the latest commits, the log errors stopped, but RBoy noticed a dashboard error message indicating Twitter login issues, even though it was still working. tgxworld mentioned that the error was fixed in a subsequent pull request.
After updating to today’s build 3.6.0 beta 2 I’m seeing errors in the logs. I checked and twitter (X) signup and login is working fine. No idea why it’s throwing these messages:
Message (67 copies reported)
A scheduled admin dashboard problem check (twitter_login) errored. : NoMethodError : undefined method `basic_auth' for an instance of Faraday::Connection
Backtrace
/var/www/discourse/lib/auth/twitter_authenticator.rb:23:in `block in healthy?'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/faraday-2.14.0/lib/faraday/connection.rb:91:in `initialize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/faraday-2.14.0/lib/faraday.rb:99:in `new'
/var/www/discourse/lib/auth/twitter_authenticator.rb:22:in `healthy?'
/var/www/discourse/app/services/problem_check/twitter_login.rb:9:in `call'
/var/www/discourse/app/models/problem_check.rb:169:in `run'
/var/www/discourse/app/models/problem_check.rb:155:in `run'
/var/www/discourse/app/jobs/regular/run_problem_check.rb:18:in `execute'
/var/www/discourse/app/jobs/base.rb:318:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management.rb:17:in `with_connection'
/var/www/discourse/app/jobs/base.rb:305:in `block in perform'
/var/www/discourse/app/jobs/base.rb:301:in `each'
/var/www/discourse/app/jobs/base.rb:301:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:220:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:185:in `block (4 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:180:in `traverse'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in `block in traverse'
/var/www/discourse/lib/sidekiq/discourse_event.rb:6:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in `traverse'
/var/www/discourse/lib/sidekiq/pausable.rb:131:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job/interrupt_handler.rb:9:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:26:in `track'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:134:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:173:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:184:in `block (3 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:145:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:118:in `local'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:144:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/config.rb:39:in `block in <class:Config>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:139:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:281:in `stats'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:134:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:133:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:85:in `global'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:132:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:40:in `prepare'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:131:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:183:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `block in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:86:in `process_one'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:76:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:10:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:19:in `block in safe_thread'
Thanks for the report, @RBoy! :folded_hands:
There was a breaking change in the Faraday gem which was updated as part of this release. It wasn’t caught by our automated testing.
A fix for the issue was just merged here:
https://github.com/discourse/discourse/pull/35407
So while the errors in the logs have stopped showing up after updating to the latest commits, I’m seeing this error on the dashboard but twitter login (it’s probably time for Discourse to change it to X now) is still working fine.
Is this a cosmetic issue or is something else going on behind the scenes?
Twitter login appears to not be working at the moment. Check the credentials in the Site Settings.
Dismiss
RefreshLast checked: October 16, 2025 6:00 PM
The error has been fixed in
https://github.com/discourse/discourse/pull/35593
This topic was automatically closed after 11 days. New replies are no longer allowed.
