Error on Topic and Post Voting Plugins
Hi all,
Just installed the latest versions of each of these plugins on Discourse 3.4.6 and got these errors
These errors completely crash Discourse and can only see a blank page.
Bummer!
Maybe update Discourse then try again?
Discourse is at 3.5.0.beta8-dev
It says up-to-date :thinking:
For the tests-passed branch, but if you’re tracking stable then I think 3.4.6 is right (3.4.6: Security fix release)
There should be a compatibility file that ensures it doesn’t pull in anything from the plugin the main site isn’t ready for, but maybe that’s gone a little awry for this last one. Hopefully someone can identify what the issue is and smooth it out. :crossed_fingers:
True enough but Discourse dev approach is so rock solid I stay with tests-passed and have nearly zero issues. :slight_smile:
Any chance @HandSpy_v3 is not using the official plugin? His OP references two plugins, like we used to have.
I’m using the Official plugins, just added in my .yml under
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-topic-voting.git
          - git clone https://github.com/discourse/discourse-post-voting.git
Brain dead, sorry. Two plugins, not one. :upside_down_face:
@HandSpy_v3 You might change to tests-passed in app.yml per Discourse recommendation.
params:
  db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
Yes, works in beta.
Generally we try to add a compatibility file into plugins to avoid situations like this, will alert the team.
Workaround is to check out an earlier version of the plugin on stable.
