Error When creating custom plugin
Dear Discourse Community,
So I am following the instructions on Developing Discourse Plugins - Part 1 - Create a basic plugin to create a discourse plugin, but everytime I add a new sub-directory in the plugins folder, and add a plugins.rb file in the sub-directory when I load up my discourse instance again I get the following error :Error while trying to load. I am running the instance as admin.
To double check, are you adding a plugins.rb or plugin.rb file? It should be plugin.rb without the s.
yeah I have a plugin.rb not plugins.rb
Can you paste the contents of your plugin.rb file here?
there is nothing in it, I am just following the tutorial
According to the tutorial (emphasis mine):
I named the directory something other than basic-plugin, does it have to have that name if the plugin.rb file is empty?
The plugin.rb file cannot be empty. Please read the guide completely and carefully!
yeah I see, I just added comments in it and now it shows up in the plugins url, thanks by the way
