this will be the least important feature needed ever, but if one can easily export the translations added to customize panel, or import strings from a table to this panel; then he can simply share it on github and it would be much easier than transifex for translation of foreign discourses.
3 „Gefällt mir“
at first enter database :
rails db
(if not in development enviroment run./launcher enter app before this code)
by runnig this code:
SELECT * FROM translation_overrides INTO OUTFILE '/home/mydata';
all data in translation_overrides table will be exported to a text file in /home/madata folder.
NOTE: you should have permission to write in this folder.
2 „Gefällt mir“
