manuel
(Manuel Kostka)
Juin 9, 2021, 10:56
1
A simple theme component that lets you add custom html to extend the short site description on the /about page. So you could add more paragraphs and insert links, or images.
The component provides an option to enter custom html:
This content is added below the default site description on the /about page:
You can also hide the default site description by checking this setting:
23 « J'aime »
mattdm
(Matthew Miller)
Janvier 13, 2022, 2:05
What about adding a config option to include that css? Like: ☑ hide default description?
3 « J'aime »
manuel
(Manuel Kostka)
Janvier 13, 2022, 11:27
3
Ah yes, I already had added that setting some time ago… updated the first post now
3 « J'aime »
This almost as neat as I’d hope it was - would it be possible to have opt in/out for Admins & Stats options as well? Many thanks.
1 « J'aime »
Moin
Octobre 22, 2023, 8:55
5
1 « J'aime »
Unless I don’t get that plugin - I was thinking: do not show whole section Admins |& Stats not just some bits.
Heliosurge
(Dan DeMontmorency)
Octobre 22, 2023, 9:15
7
There is maybe a bit of confusion.
The component @Moin linked allows you to hide admin/mods from about page.
You would need to make a custom Theme component and add css that provides a condition.
Not the code but along thr lines of.
If not admin/mod on About page Stats display none.
If your good with css you can use your browser to identify the element to target.
1 « J'aime »
Thank you @manuel ! Exactly the component we were looking for.
Hide default description doesn’t seem to work, though?
manuel
(Manuel Kostka)
Mars 28, 2025, 10:13
9
I believe this component is no longer necessary. There’s a new layout for the about page and you can add content right in the admin settings:
Could someone with tagging permission tag this as end-of-life?
6 « J'aime »
