Failed building stable due to 3rd party plugin
The discussion revolves around a failed attempt to rebuild a stable version of Discourse due to a compatibility issue with the 3rd-party discourse-locations plugin. TerminalAddict encountered an error while running rake db:migrate, which was caused by the plugin. sam pointed out that the plugin is no longer compatible with the stable version of Discourse. TerminalAddict acknowledged the issue, and angus, the plugin author, apologized for not clearly indicating that the plugin is only compatible with the latest version of Discourse.
Hey all,
can’t seem to rebuild stable today
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 13067 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
39a6896636b4ad5f5fb7f82cc9bc13d96bb84e6c88f4260ed9241d5025baa074
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
I’m also seeing (further up)
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.1/exe/rake:27:in <top (required)>
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => db:migrate => db:load_config => environment
and
I, [2019-01-07T04:35:29.137437 #14]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
This monkey patch is no longer required.
rake aborted!
NoMethodError: undefined method `attributes' for DirectoryItemSerializer::UserSerializer:Class
Did you mean?  attr_writer
/var/www/discourse/plugins/discourse-locations/plugin.rb:83:in `<class:UserSerializer>'
/var/www/discourse/plugins/discourse-locations/plugin.rb:82:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:298:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:296:in `each'
/var/www/discourse/lib/plugin/instance.rb:296:in `notify_after_initialize'
/var/www/discourse/config/application.rb:256:in `each'
/var/www/discourse/config/application.rb:256:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:69:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:62:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:67:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:51:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application/finisher.rb:75:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application.rb:361:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/config/environment.rb:5:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies.rb:283:in `require'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies.rb:283:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies.rb:249:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application.rb:337:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application.rb:520:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.1/exe/rake:27:in `<top (required)>'
This 3rd party plugin (discourse-locations) is no longer compatible with stable.
Thanks @sam .. I missed that bit of news :slight_smile:
Sorry, I should have made it clearer in the plugin description that the Locations Plugin, and all my other plugins, are always compatible with the latest version of Discourse.
