重建失败,原因是插件不兼容
Hi I did a rebuild today but I got the following message, now my site is offline:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 10840 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
d07f84b6b2115126ba6c11e8d51bd41f7e5963a736d8142c183bb96e18919e78
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
I’m a bit of a noob and don’t know what to do with this, hope someone can help me out, thanks!
Matt
You need to scroll up, that is not the official error, there should be another up further up. Also, if you could list any plugins you are using, that would help (they are the typical culprit of these errors at upgrades)
3 个赞
Thanks!
Problem solved:
该主题在 2438 天后自动关闭。不再允许回复。
