Received bundler out of date message updating Discourse, so I built the container as advised. That seemed to work except that I got a message that there was already a server running on port 80. Tried rebooting the server. Now server’s throwing off a 500 error loading any page.
Admittedly I’m out of my depth with docker and discourse.
Tried rebuilding container bc… no good reason which generates the following error.
FAILED
RuntimeError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 297 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
Rerunning ./launcher rebuild app, the only errors…
database "discourse" already exists
role "discourse" already exists
column "like_notification_frequency" of relation "user_options" already exists
StandardError: An error has occurred, this and all later migrations canceled:
FATAL: xlog flush request 0/E91964B8 is not satisfied --- flushed only to 0/E9159030
and the process ends
2016-03-02 23:41:44 UTC [67-6] LOG: abnormal database system shutdown
195:M 02 Mar 23:41:44.148 # User requested shutdown...
195:M 02 Mar 23:41:44.149 * Saving the final RDB snapshot before exiting.
195:M 02 Mar 23:41:44.271 * DB saved on disk
195:M 02 Mar 23:41:44.272 # Redis is now ready to exit, bye bye...
Something really bad is going on here. Your database is in a completely pantsed state. xlog flush request is not satisfied smells… diskspacey, maybe? At any rate, you’ve broken something real good. How’s your backups?
Please paste the output of df -h, free -m, docker info and docker version.
