Failed to bootstrap using import template
Fresh install of discourse_docker returns a failed to bootstrap error when trying to build the import container. I’m using the phpbb3.template.yml and the instructions listed here.
I had this working a day or so ago and then it started failing. I’ve completely refreshed the droplet and pulled down the latest code but I’m still seeing the same issue. Anything change recently?
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle install --no-deployment --path vendor/bundle --jobs 4 --without test development' failed with return #<Process::Status: pid 1413 exit 16>
exec failed with the params {"cd"=>"$home", "cmd"=>["echo \"gem 'mysql2'\" >> Gemfile", "echo \"gem 'ruby-bbcode-to-md', :github => 'nlalonde/ruby-bbcode-to-md'\" >> Gemfile", "su discourse -c 'bundle install --no-deployment --path vendor/bundle --jobs 4 --without test development'"]}
271446b749aeda761682dafac773a3b7266cb6f9574465bcfdc50c3812f3a509
A few lines above your text it says what to do (though rather cryptically). See Nothing displayed on launcher rebuild - #5 by pfaffman for some slightly-better hints.
Thanks @pfaffman that worked!
Great! Here’s a PR: FIX: mysql-dep template--un-freeze the Gemfile by pfaffman · Pull Request #457 · discourse/discourse_docker · GitHub
