Forum update failed – how to restore or reinstall with previous data?
Hello,
My forum update ran into problems and is now unusable. I would like to know how I can reinstall Discourse while exporting and re-importing my previous data.
It seems that Discourse is set by default to periodically save forum backups. In the worst-case scenario, where can I find and export these system default backups?
Of course, if the issue can be directly resolved without reinstalling, that would be even better.
For context, here is what I did:
  1. From the admin panel, I clicked “Update Docker”.
  2. Then I upgraded the forum via command-line.
  3. After the update completed, the forum stopped working.
I have attached the error log in this thread for reference.
Any help would be greatly appreciated!
You can restore it like this:
Also see:
