Get rid of mobile-desktop toggle from mobile sidebar
The discussion revolves around removing the mobile-desktop toggle from the mobile sidebar, given that desktop view isn’t intended for mobile use. Jonathan5 initiates the idea, citing that the toggle is redundant on devices that can’t properly handle desktop view. Lilly notes its utility for users unfamiliar with browser-based view changes, while awesomerobot explains the toggle helps when user agent detection fails. DaVania suggests hiding it by default but making it user-selectable, with admin control over the default. Jagster identifies three use cases where the toggle is still valuable: mobile devices with the docs plugin, tablets needing view flexibility, and desktop users preferring minimalism. The toggle has since disappeared, prompting further discussion on balancing usability and simplicity.
Continuing the discussion from Can't post message using desktop view on mobile:
As we are not meant to use desktop view on mobile, the toggle allowing us to enter desktop view should be removed from the sidebar, at least for all screen sizes that can’t cope with desktop view.
Thanks for considering this “feature un-request” / “un-feature request”!
yea it’s a bit redundant but a lot of users don’t know how to change views via browser, so the function helps that way. i change a lot on my ipad but i usually use the browser text method.
We switch between mobile/desktop views by detecting the browser’s user agent… and this isn’t always 100% accurate, so these buttons can help in a “worst case” scenario where you find yourself in the wrong view.
that’s a great point.
Maybe just remove it in cases when you’re 100% sure the user shouldn’t enter desktop mode. Unless those cases don’t exist! :slight_smile:
The toggle seems to have disappeared! :slight_smile:
I think the best solution would be to have it removed/hidden by default, and user selectable if so desired by the individual user, perhaps make it so that the default is controlled by admin setting.
It is also nice to have the switcher available, when debugging themes, since mobile view on desktop sometimes gets caught/frozen.. when I cannot remember the querystring to manually set the desired view mode, I use the developer tools to change the view class of the HTML root element.
There are three situations AFAIK when that toggle is needed or wanted:
  • mobiles when docs plugin and filters are in use
  • tablets because every now and then desktop view is not suitable and vice versa
  • when a desktop user wants the cleanest and monimalistic view and doesn’t owe a 22 inch screen
And yes, it could be another user setting.
