「Glimmer」のトピックリストモードがトピックリストの解決済みチェックボックスを隠しています。
I’m not sure what, but looks like something Looks like the glimmer topic list mode setting is hiding the topic solved status in the title line of Topic list pages on Meta - the code for the solution checkbox goes missing when that setting is enabled (thanks @Moin for pointing out which setting was doing it).
Meta
Topic list view:
Topic view:
Console:
On my hosted instance, where it is displaying as expected with Glimmer topic list mode disabled.
I am seeing it in multiple browsers, mobile and desktop, on my Macbook and Linux machine, iphone and ipad.
「いいね!」 8
Oh yes, I was also wondering why that Meta topic didn’t have the checkbox in the topic list. Android, can repro.
「いいね!」 2
This will make the ‘auto’ glimmer-topic-list-mode aware of the problematic modification:
Once merged, that’ll auto-disable the glimmer topic list on Meta. Then we can follow-up with a fix to the solved plugin. (might need to add a new transformer API to core to support this use-case :eyes:)
「いいね!」 6
This is working now.
「いいね!」 2
