Google will be treating nofollow links differently
Google announced that it will not be treating the rel="nofollow" attribute as a signal any more, but as a hint. The background is that so many CMS’es are designating every link as nofollow.
They’re introducing two new hints: ugc for user generated content and sponsored for paid links.
For the UGC, they’re explicitly mentioning forums.
My opinion is that this is a big step forward, since the vast use of nofollow was killing the idea behind PageRank.
Full announcement here: Official Google Webmaster Central Blog: Evolving “nofollow” – new ways to identify the nature of links
Changing the code to use “nofollow ugc” seems like a fairly straightforward and safe thing for Discourse to do.
The above is my personal opinion and not necessarily that of Google, LLC
It it valid to use both? Should it just be “ugc” now? I am unclear.
From that blog’s FAQ:
Can I use more than one rel value on a link?
Yes, you can use more than one rel value on a link. For example, rel=“ugc sponsored” is a perfectly valid attribute which hints that the link came from user-generated content and is sponsored. It’s also valid to use nofollow with the new attributes – such as rel=“nofollow ugc” – if you wish to be backwards-compatible with services that don’t support the new attributes.
What “services” support nofollow other than Google?
Baidu, Yandex supports nofollow
Bing, as a hint
Can you assign this @eviltrout? I assume it is a very very simple change, almost a copyedit?
Hey @Roman this is probably an easy one, please take a look!
We’re now using nofollow ugc:
Latest Onebox version is using it too:
On 2.6.0.beta2 I’m getting rel="nofollow noopener" with no ugc attribute for external links. Anyone else?
Edit: Looked for a recent link posted on meta. Seems that it’s also the case here: What is this line for in a Discourse forum's RSS feed?
Not seeing the ugc attribute either, will take a look.
Fixed here:
Links will correctly use nofollow ugc now.
