Have tag notification settings override category notification settings
To replicate current functionality:
  1. as user A set category notification setting to watching
  • as user A set tag notification to muted
  • log out of user A account
  • log in as user B
  • as user B, write a test post in the category and containing the tag
  • **user A will be notified of post **
So it appears that category watching settings override the tag watching settings. I’d like to suggest reversing this so that if you have muted a specific tag, you will not be notified even if it’s in a category you are watching.
Or perhaps this can be an admin or user setting to serve different communities?
1 个赞
What is the order of operations here @neil?
The behaviour is the same. It also works the other way. If you are watching a tag but mute a category, then you will get notified of a topic with that tag and category. Watching is stronger than muting.
4 个赞
Is this also true if the same topic has two tags: one watching, the other muted?
Yes you’ll see topics that have tags that you’re watching.
1 个赞
