Hi,
I’m using the hosted discourse installation, and have configured the google oauth2 settings.
The callback url called from google is setup correctly, but then gives the user a 502 on discourse.
Regards,
Robert
Hi,
Regards,
Robert
Hi Robert,
I was able to signup using Google (a gmail address), and to log in to an existing account with Google too (my discourse.org address). Can you give us any other info that could narrow it down?
Neil
That’s where I tested. You’ll see in your users list that I have two accounts. One was created with Google Oauth, the other one was a signup without Google Oauth and then log in with Google later. Both cases worked for me.
OK, then the issue is either solved, a heisenbug or related to the google accounts we tested it. thanks.
