Configure Google login for Discourse
:bookmark: This guide explains how to set up Google login integration for your Discourse site by configuring OAuth2 credentials in the Google Cloud Console.
:person_raising_hand: Required user level: Administrator
Overview
Google login allows users to sign in to your Discourse site using their Google accounts. This guide will walk you through:
  1. Creating a Google Cloud project
  2. Setting up OAuth consent
  3. Configuring credentials
  4. Enabling Google login in Discourse
Create a Google Cloud project
  1. Navigate to https://console.developers.google.com
  2. Click the project selection button in the top left
  3. Click “New Project”
  1. Enter a project name and optional location.
  2. Click “Create”
:information_source: If you see any errors after creating the project, refresh the page using Ctrl+F5.
Configure OAuth consent
  1. Navigate back to https://console.developers.google.com and select your new project if it is not already slected.
  2. Navigate to “OAuth consent screen” in the left panel. You can also use the top left Google Cloud menu to select “APIs & Services” → “Oauth consent screen”.
  1. Click “Get Started”
  2. Under “App Information” enter an app name and select a user-support email address.
  1. Select “External” Audience
  1. Next, enter a notifications email address
  2. Finally, accept the API Services: User Data Policy and click “Create”
Set up credentials
  1. Navigate to the “APIs & Services” → “Credentials” screen
  2. Click “Create Credentials” and select “OAuth Client ID”
  1. Configure the OAuth client:
  • Select “Web application” as the Application Type and give it a Name
  • In Authorized JavaScript Origins, add your site’s base URL (including https://)
  • Add your callback URL under Authorized Redirect URIs: https://your-discourse-site.com/auth/google_oauth2/callback
  • Click “Create”
Click on the OAuth 2.0 Client ID:
Copy the ClientID and Client Secret to add to your Discourse admin:
Configure Discourse settings
  1. In your Discourse admin settings under “Login & authentication”
  • Enable the setting enable google oauth2 logins
  • Enter your google oauth2 client id
  • Enter your google oauth2 client secret
Verify and publish
Test the integration by adding a user with a Google email address and confirming you can log in to Discourse using the “Log in with Google” option. If you are able to log in then the configuration is complete! :tada:
:warning: NOTE:
Previously there was one final step required - changing the Google Developer Project to production status. This no longer appears to be required. We are leaving these legacy notes here just in case.
To make the integration publicly available:
  • Change the status to “In production”-
  • Complete Google’s verification process
  • Verify site ownership through Google Search Console
Additional configuration
Google OAuth2 prompt
The google oauth2 prompt setting controls the behavior of Google’s consent screen during login. Available options:
  • (blank) — default Google behavior
  • none — no consent or account selection screen shown
  • consent — always show consent screen
  • select_account — always prompt the user to select an account
Google Workspace (formerly G. Suite, Google Apps) login
To restrict login to specific Google Workspace domains:
  1. In Discourse Admin -> Login & authentication, locate the google oauth2 hd site setting
  2. Enter your Google Workspace domain
Google Workspace group sync
You can automatically sync Google Workspace groups with Discourse. This requires:
  1. Enable the google oauth2 hd groups setting
  2. Set google oauth2 hd to your Workspace domain
  3. Enter a Workspace admin email in google oauth2 hd groups service account admin email
  4. Paste your Google service account JSON credentials into google oauth2 hd groups service account json
The service account must have domain-wide delegation enabled and be granted the https://www.googleapis.com/auth/admin.directory.group.readonly scope. See Google’s documentation on domain-wide delegation for setup instructions.
Troubleshooting
If you experience login issues:
  • Verify that HTTPS is properly configured
  • Double-check all redirect URIs
  • Ensure your site’s SSL certificate is valid
  • Confirm that all required Google Cloud APIs are enabled
  • Enable google oauth2 verbose logging to get detailed OAuth2 request/response logs
Related resources
Unfortunately, if I follow the instructions, the login does not work.
In order to get the login to work, I had to add both URL formats for redirection.
https://forum.example.com//auth/google_oauth2/callback http:///forum.example.comauth/google_oauth2/callback
However, I am now unable to submit the app for publication because Google only requires addresses in the HTTPS format.
Any advice on how to solve this?
I guess you don’t have a standard install and need to turn on force_https.
I followed the official installation. Force HTTPS is enabled.
EDIT: It’s weird, but now it’s started to work! I tried it at least ten times before, but it didn’t work.
I can’t explain it because the procedure was exactly the same. Maybe something on Google’s side?
:person_shrugging: It makes no sense that it’d be accessing google with http.
A post was split to a new topic: Google login regression, possibly after recent changes
Hello, thank you, I set up the procedure today and it works fine. I tested it with another Google account that belongs to me. However I have a small question, I tried to register with this other Google account from my PC and I only got the access key option. I had to activate Bluetooth to communicate with my phone. Well, all that didn’t work at all. What I really wanted to do was click on the connect with Google button and then complete the procedure by simply filling in the form without using an access key. I’m on my PC, I don’t necessarily have an access key, no fingerprint. What do I do if I want to use this procedure, register with Google if I’m not on my phone? Thanks.
