Hi, I guys i know i can add a category in from /categories link but i want to add a child category in a new category where can i do that ?
Same button, you simply fill out the parent category field to make it a sub-category
This looks like a heavily customized instance. Try disabling your customization.
Can you show me how ?
I’m a newbie and a bit confused
In the admin panel, navigate to the Customize section, select CSS/HTML, select your customization, disable it and save – repeat if you have more than one customization.
You can re-enable them there later on, if you want ![]()
Thank you so much worked like a charm.
