如何找到512*512的图标
I’ve updated discourse to 2.2.0.beta8.
But it always reports a problem:
Your site is missing a 512 × 512 icon, which allows users to add a home screen
shortcut to this site on Android devices.
Go to the Site Settings and upload a 512 × 512 icon.
I tried a random picture which is not 512 * 512, the problem remains.
I tried to download a 512 * 512 picture, but the problem still remains.
So, how can I solve the problem?
Fine, I see the picture is not exactly 512 * 512.
It must be exactly 512 x 512 pixels in size, see Discourse 2.2.0.beta8 - PWA Error for background discussion.
Are you sure it displays the same warning after you click refresh? On some installations it then also gives a warning about the short title not set or being too long, which can give the impression that the original problem remains, while in fact it’s a different one.
2 个赞
You are right, the picture have to be exactly 512 * 512;
Now it works, seems I have to cut my picture as exactly this size.
3 个赞
