How can i help in the translation of missing strings
there are some few strings which can not be translated through the “admin → customize → site_texts” tab; I mean if you change the text in the admin-text panel, nothing will happen in the main forum.
some of them are in the tag plugin; mentioned here:
https://meta.discourse.org/t/customize-all-text-in-discourse/36092/22
and
https://meta.discourse.org/t/customize-all-text-in-discourse/36092/44
and some others with the “selected answer” feature.
currently i use a simple css trick to cover the issue, e.g.:
.ember-view .tag-drop .tag_all {   font-size: 0px;}
.ember-view .tag-drop .tag_all:after {
    content: "موضوع";
    font-size: 15px;}
but this is not the best way to do it.
is there anyway i may help in this issue, so that localized discourse can be as good as the English version?
2 « J'aime »
