Happy New Year to everyone
How can i make the “tags” as REQUIRED when create a new Topic,Thank you
thanks a lot.
by the way ,is there a option to add a global site setting,i mean if user have no choose the category…
No there is no such global site setting as of now.
so only adds a setting for each category to set “minimum required tags”,and if there no select on category (uncategorized), isn’t work? ![]()
*Thank you for your quick reply
Can anyone give me specific directions to this setting? Simply can’t find it! ![]()
Thx. i was looking in my overall site settings as distinct from the category setting. Been away for 5 years and have forgotten a bit and/or things have changed a bit! ![]()
