כיצד ניתן להסיר קטגוריות ילד מתצוגת הקטגוריות עם נושאים מוצגים?
I’d like to remove the sub-category from this view. Does anyone have any idea how to do that?
Jacob
You can add this CSS to your theme:
.subcategories {
    display: none;
To:
I’m not sure .subcategories is the best selector though. I don’t know if it’s used elsewhere on the forum. Then it may cause unintended effects.
So you can use this instead :D.
.categories-list .category-list.with-topics .subcategories {
    display: none;
thanks @Canapin and @Lhc_fl
Yeah, that would be safer.
edit: I took a look at Discourse’s code, .subcategories alone should be safe (I personally like to use not too much selector depth if I can avoid it), and you should also consider hiding .subcategories-list as well as it’s the subcategories parent container on the mobile view.
