如何自动本地化常见问题和“关于”分类
I’ve my forum instance in Spanish, but all the files generated like the TOS, FAQ, all the categories About topics are in english, is there any way to translate those files, maybe a rake task. Or I need to get to the server.es.yml file and start copying and pasting?
Did I do something wrong while I was setting up the Discourse?
4 个赞
tos_topic is definitely already translated to Spanish.
To update it I think the simplest way would be removing the link to the topic in the DB and doing a rebuild.
I agree it is not that great that we seed these topics before you have picked a locale. @gerhard we should think of a better long term solution here.
What we can do is glue a custom field to the topics we create so when you change locale, a rebuild brings in the correct topics.
So in 990_topics.rb
  1. When creating these topics we set the custom field of topic_locale.
  2. IF we have SiteSetting.XYZ_topic_id, THEN look at custom field… IF it is there and locale does not match current locale, create a new topic.
This is not 100% ideal, cause there is a big delay (has to wait for a rebuild)
BUT if we triggered the same process on SiteSetting change it could be workable. I really dislike that SO MANY sites have TOS etc in the wrong language.
To work around:
./launcher enter app
rails c
SiteSetting.tos_topic_id = 0
SiteSetting.guidelines_topic_id = 0
SiteSetting.private_topic_id = 0
exit
exit
./launcher rebuild app
7 个赞
I added a rake task as a first step. It’s now possible to update all seeded topics and categories by running the following commands:
rake i18n:reseed[locale]
7 个赞
Just so this does not get lost, we should do “dialog” when you switch site settings for locales allowing mods to opt to update the various topics if they wish.
2 个赞
Completely solved by Update seeded categories and topics
2 个赞
