A user asks how to configure a group’s email address in Discourse, noting that the option is missing in their updated instance. simon explains that the ‘email in’ Site Setting must be enabled first, then the user should navigate to the group’s page, go to the Manage tab, select Interaction, and enter the email address in the provided field. serquicia confirms that enabling the ‘email in’ setting resolved the issue.
I’m trying to configure the email address of a group in Discourse and I cannot find where.
I’ve seen in Configuring incoming email to create new topics or group messages that there was an option at group configuration that was called “Custom incoming email address”. I’m using an updated instance of Discourse and there is nothing like that and the page is a little different than the screenshot.
To configure the incoming email address for an existing group, first make sure that the ‘email in’ Site Setting is enabled. Then, go to your groups page, click on the group’s name from the list to get to the group’s page. On the group’s page, click the Manage tab and then click Interaction from the left-side menu. You should see a form that looks like this:
