How to create a copy of the Foundation theme?
rlauriston asked how to copy the Foundation theme to customize it for adding ad codes. merefield suggested that copying may not be necessary, recommending instead to create a Theme Component and add it to the existing theme. awesomerobot clarified that “Foundation” is actually the base style set for all Discourse themes rather than a standalone theme, and advised using plugin outlets for adding content instead of editing templates, providing a link to further guidance on using plugin outlet connectors.
How can I create a copy of the Foundation theme so I can customize it to add ad-related codes to the header, body, and footer? Or is that the wrong approach?
You may not need to.
Just create a Theme Component and add that to the Theme.
To expand on that a little more, “Foundation” isn’t technically a theme, it’s all the default styles Discourse comes with. Every Discourse theme is built on top of Foundation as a base.
If you’re looking to add content to Discourse, you want to look for plugin outlets rather than any sort of template edit/override… there’s more guidance here Using Plugin Outlet Connectors from a Theme or Plugin
