How to create leftsidebar tags section ? based on attachment
That’s part of Discourse core, no? You can edit the section using this:
Also, see this guide on how to configure the sidebar section ad an admin:
I am looking for categories and tags like in the first screenshot, but I’m still confused. Please help me.
Those categories are site-dependent. Each forum has their own set of categories.
Categories are not an issue, the only problem is that the bottom tags section is not showing in my forum. Please guide me.
Do you have any tags on your forum?
You can create tags by following this guide:
Tags Uploaded now showing tags section after login. but not showing after logout ?
Hmm… did you try this?
Hi, thank you. I have installed the top search component on my forum (https://forums.sprukomarket.com/), but the large site search banner is still showing. I tried adding custom CSS to remove it, but it doesn’t disappear. What could be the issue?
I assume you are referring to the Welcome Banner. In that case, you will need to disable it in the theme settings. Go to Admin > Appearance > Themes, select the theme you are using, and uncheck the Enable welcome banner setting you are using. (Judging by the look, I think that’s the Foundation theme)
