Cómo crear una etiqueta en c++ o Notepad++
¡Hola!
Intenté crear una etiqueta de C++ pero fallé.
He creado una etiqueta que parece C++ pero es “c++”, sin embargo, cuando el usuario escribe en la URL “c++”, aparece el error “¡Ups! Esa página no existe o es privada”.
¿Cómo se crea el carácter más en la etiqueta?
Gracias.
Check out this topic:
https://meta.discourse.org/t/using-a-tag-named-c-its-not-possible/92005?u=tophee
1 me gusta
It is unbelievable to have a website that uses this tag “c++”
Cards in the menu
c%20%20%20menu
Tag on url
c%20%20%20url
how to be like that?
+ is tricky, it often needs to be encoded, at the moment our tag system does not support tags with + in them. We should either fix this or at least validate you do not create tags with +
Going to mark this as a bug cause it leads to confusion and we need to pick a side here vs allowing you to create a broken tag.
5 Me gusta
I know the tag system does not support + tags in it.
How to get the “+” card in card management
Please get any suggestions.
Thank you
Notepad++ should be doable with this little trick
.tag-notepad::after {
    content: "++";
I didn’t try it, but it should work everywhere on your forum
But you should avoid doing the same for c for now, given @tophee’s post
1 me gusta
@Steven What do you think of this site as having tag “+” Topics tagged c++
I honestly don’t know. You can try to contact them, there’s the email address in the about page. I can’t really help on this issue
1 me gusta
Thank you.
I contacted them but did not receive the answer.
I hope to find the answer from the community Discourse
¿Alguna novedad sobre este tema? Me gustaría crear también una etiqueta c++.
