¿Cómo personalizar el menú desplegable de usuario?
I would like to add a direct link to the users activity page to the user dropdown menu, either as an icon:
Or as text.
How do I do it?
Create a new CSS/HTML customization, and put this in “</head>
<script type="text/discourse-plugin" version="0.4">
    api.addUserMenuGlyph({
        label: 'awesome.label',
        className: 'my-class',
        icon: 'your-icon',
        href: `/some/path`
</script>
How do I write the href path if it includes the username (as in /users/username/activity)?
Note to anyone wanting to use this: if you use an fontawesome icon, you give the icon name without the leading fa-
You can cheat and use “/my/activity:wink:
And how do I compose the label properly (so that I can draw on existing localizations)?
And what about the mobile version? There is no <\head> in the mobile version…
You can have a look at the client.en.yml file if you want to use existing localizations.
</head>” works for both.
Excellent! Based in what I saw in client.en.yml, I tried label: 'activity_stream' but it didn’t work. label: 'activity' works.
That’s because “activity_stream” is under “user” and should thus be referenced as “user.activity_stream:wink:
You are a great teacher. Thank you very much!
Same method for that?
¿Existe alguna forma de hacer esto pero para el menú de acceso rápido del perfil?
¿Cómo se podría agregar un enlace allí?
Perdona por revivir un tema antiguo, pero esto parece estar relacionado.
