How to display homepage content with Categories Names only (without topics)
Hello I have researched every tabs and looked into this forum for possible solution, but without luck.
I have 2 categories, and i only want them show up at my homepage.
Currently, homepage shows the topic in each category.
I only want topic in each category to show up after the visitor check either Patreon (1st category) or Gumroad (2nd category).
My current project is below
Thank you for the kind consideration!
Welcome to Meta :wave:
You can move “categories” to the top of the top menu in the site setting. Then it will be the default homepage
Thank you SOOOOOOOOOOOOOOOOO much! It took me so long to try to solve it (i even try the subcategory thing).
You are awesome, Moin!
