איך להשתמש במודול "נושאים" בדף הבית של האתר?
סיכום מבוסס בינה מלאכותית
To set the “topics” module as the homepage, HAWK suggests rerunning the setup wizard, which offers homepage configuration options. Lilly provides more details, stating that as an admin, one can also change the default homepage in the admin - all site settings - top menu ordering. The top menu item becomes the default homepage. Alternatively, users can change their own default homepage in their preferences - interface. Elena confirms understanding the solution.
When I enter into the website firstly,“all categories” module is the homepage,how to set "topics"module as the homepage?
The easiest way is to rerun your setup wizard which gives homepage config options.
If you are admin and you want to set the default homepage to something other than categories, you can run re-run your setup wizard, like Hawk said. Or you can also change it in the admin - all site settings - top menu ordering. The menu item at the top of the list is the default homepage (you can also add and remove the nav bar items there too). For example, on Meta, the default homepage is /latest.
If you are a regular member of a Discourse forum and want to override this and change your own default homepage, you can do it in your preferences - interface - default homepage setting.
I got it,thanks a lot !
