איך למחוק פוסט לצמיתות?
סיכום מבוסס בינה מלאכותית
Permanently Deleting a Post
Bitweb_Core is seeking a way to permanently delete a post, mentioning a console method using Post.find(THE_POST_ID).destroy. However, they are unsure how to find the post ID.
JammyDodger suggests enabling a hidden site setting, which allows permanent deletion from the UI. Instructions can be found here.
Once enabled, a “Permanently Delete” option is added to the post wrench JammyDodger. There are safeguards in place, including a 5-minute delay before the same administrator can permanently delete a post, and the ability for a different administrator to delete immediately.
Qustion is how i can permanet delete post. thread ?
i was see there was
./launcher enter app
rails c
but no really undestand how find it id , and how to delete it compleate .
You can permanently delete from the console, but there is now an easier option that will allow you to do it from the UI. :+1: You do need to enable a hidden site setting, but you can find the instructions here:
is that will be enabled for all posts or that will be only like option ?
example “hide or delete”
It adds an option to the post wrench:
There are a couple of safeguards too, and a bit more detailed info in this topic:
