How to remove discourse website
This CMS is a very good, but a lot of things modified. As difficult installation, modification, and so the addition of a plugin and etc.
I want uninstall my discourse website? Which command do I have to write for that?
I’m not sure what you are asking? Are you looking to wipe the content of the forum?
rm -r /var/discourse
Will delete Discourse and all backups and everything. I’m not clear why not just shut down the droplet, though.
After
site down.
500 Internal Server Error
If you are the administrator of this website, then please read this web application’s log file and/or the web server’s log file to find out what went wrong.
I want remove delete discourse cms from my website. How delete docker and discourse?
Edit: I just checked, and if you installed Docker with the http://get.docker.com’s script and are running Ubuntu,
apt-get purge docker-engine
should remove docker. You’ll probably need to reboot to make sure all docker processes get killed.
In short: whatever you did to get Discourse running, do the reverse of that.
If you want to completely remove discourse:
  1. List you local docker images from the host: docker images
  2. Find the discourse image. It should look something like
    REPOSITORY            TAG                 IMAGE ID            CREATED             SIZE
    discourse/discourse   1.3.10              95332d4db04b        5 weeks ago         1.52GB
  3. Remove the image: docker image rm discourse/discourse:1.3.10. Remember to use the exact same name and version your docker output showed you.
  4. Remove the location you cloned the discourse. If you followed the installation instructions, it should be /var/discourse, so rm -r /var/discourse should do it.
  5. [optional]. If you don’t need docker anymore, remove it from your machine.
Très bonnes commandes. Je me posais aussi la question à leur sujet.
Deux petits points :
J’ai reçu le message "Impossible de supprimer la référence du dépôt “nom de l’image” (forcez) : le conteneur iccfa6e6d14b utilise son image référencée 654a4f02e531.
  1. Comment pouvons-nous empêcher l’image d’être utilisée ? Si nous éteignons le droplet, la console ne fonctionnera plus.
  2. Docker est-il une entité distincte du système d’exploitation Ubuntu Server sous-jacent ?
Merci.
Si vous supprimez le droplet, Discourse disparaît avec lui, donc tout cela n’a plus d’importance, mais…
Je pense que vous devez exécuter :
docker stop app
Ou :
. /launcher stop app
Avant de pouvoir supprimer l’image.
Encore merci.
Mais j’aurais aimé que vous répondiez aussi à ma 2ᵉ question, qui, je crois, devrait tenir en une seule ligne.
J’ai cherché cette réponse sur Google pendant environ une heure.
J’ai également lu toute cette discussion sur le sujet sur Meta, ici.
Mais je n’ai pas réussi à comprendre.
Je peux reformuler mon dilemme :
Est-ce que la situation est la suivante :
il y a le système d’exploitation Ubuntu, puis une installation Docker normale dessus/dedans.
Et dans cette installation Docker, Discourse Docker s’exécute ?
Ou est-ce simplement Ubuntu Server OS avec Discourse Docker installé/exécuté dessus ?
Ou cela ne s’appelle-t-il pas « Discourse Docker » mais quelque chose d’autre ?
P.S. : J’ai aussi essayé de comprendre la même chose grâce à ce long sujet. Mais cela n’a pas tout à fait répondu à ma question (ça y a presque été, mais pas tout à fait).
Oui. Vous avez Ubuntu comme système d’exploitation, puis Docker comme application installée sur le système d’exploitation, et Discourse qui s’exécute au-dessus de Docker.
Docker permet d’isoler les applications dans des conteneurs (simplifions cela comme une machine virtuelle légère), où vous pouvez exécuter plusieurs applications sans perturber le système d’exploitation.
J’ai supprimé le conteneur de données Docker (et peut-être aussi web_only), mais même lorsque je réinstalle ou recrée le conteneur de données, les mêmes administrateurs/utilisateurs (et paramètres) réapparaissent.
Je voulais repartir de zéro pour installer Discourse à neuf. Dois-je vraiment désinstaller Docker pour cela ? Ou supprimer tout le dossier /var/discourse ?
N’existe-t-il pas un dossier ou un emplacement spécifique qui contient toutes les données, et dont la suppression effacerait tous les paramètres, utilisateurs, administrateurs et publications de Discourse ?
Merci.
rm -rf /var/discourse/shared
Ensuite, reconstruisez. C’est là que les volumes persistants sont stockés par défaut.
