How to use Amazon SES for sending emails to users?
סיכום מבוסס בינה מלאכותית
Using Amazon SES for Sending Emails in Discourse
To integrate Amazon SES with Discourse, configure the email settings in your app.yml file with the following:
  • DISCOURSE_SMTP_ADDRESS: email-smtp.us-east-1.amazonaws.com
  • DISCOURSE_SMTP_PORT: 587
  • DISCOURSE_SMTP_USER_NAME: Your Amazon SES credentials
  • DISCOURSE_SMTP_PASSWORD: Your Amazon SES password
  • DISCOURSE_SMTP_ENABLE_START_TLS: true
After updating the configuration, run ./launcher rebuild app to apply the changes.
Additionally, if you’re using Amazon SNS to track Amazon SES emails, you can add a custom email header to specify the configuration set that triggers the SNS topic. To do this, add the following header:
X-SES-CONFIGURATION-SET: ConfigSetName
Replace ConfigSetName with the name of your configuration set.
To set custom email headers in Discourse, follow these steps:
  1. Go to your Settings Panel >> Email or use the link https://forums.example.com/admin/site_settings/category/email (replace with your own domain).
  2. Search for email custom headers and set your own header.
Hello All I want to query how to configure and integrate Amazon SES with discourse to use it for sending emails from an verified Amazon SES email.
This is pretty easy to setup, in your app.yml:
  ## TODO: The mailserver this Discourse instance will use
  DISCOURSE_SMTP_USER_NAME: CREDIENTIALS
  DISCOURSE_SMTP_PASSWORD: CREDIENTIALSPW
Worked straight out of the box for me.
Edit:
To apply these changes you will need to run: ./launcher rebuild app
For anyone else searching, if you do use Amazon SNS to track Amazon SES emails, you can add a custom email header to specify the config set that triggers the SNS topic:
ConfigSetName is the name of the configuration set.
That seems to be working for me. I’m planning to have SNS send all the SES logs from different parts of our sites into one place.
For those who are wondering how to set the custom email header, here it is.
  1. Go to your Settings Panel >> Email or use below link
    https://forums.example.com/admin/site_settings/category/email, you should replace the domain name with your own.
  2. Search for email custom headers, and set your own. That’s it!
