Hi Daniella, I have tried this integration with three different chat providers and keep getting the same CSP after adding all the links I could find to security policy script src. This particular one is for Tidio, but the same thing happened with LiveChat and Pure Chat. Any ideas what may be happening here?
Content Security Policy: The page’s settings blocked the loading of a resource at eval (“script-src”). Source: (function injected(eventName, injectedIntoContentWindow)
  let checkRequest;
   * Frame context wrapper
   * For some edge-cases Chrome will not run content scripts inside of frames.
   * Website have started to abuse this fact to access unwrapped APIs via a
   * frame's contentWindow (#4586, 5207). Therefore until Chrome runs content
   * scripts consistently for all frames we must take care to (re)inject our
   * wrappers when the contentWindow is accessed.
  let injectedToString = Function.prototype.toString.bind(injected);
  let injectedFrames = new WeakSet();
  let injectedFramesAdd = WeakSet.prototype.add.bind(injectedFrames);
  let injectedFramesHas = WeakSet.prototype.has.bind(injectedFrames);
  function injectIntoContentWindow(contentWindow)
    if (contentWindow && !injectedFramesHas(contentWindow))
      injectedFramesAdd(contentWindow);
      try
        contentWindow[eventName] = checkRequest;
        contentWindow.eval(
          "(" + injectedToString() + ")('" + eventName + "', true);"
        delete contentWindow[eventName];
      catch (e) {}
  for (let element of [HTMLFrameElement, HTMLIFrameElement, HTMLObjectElement])
    let contentDocumentDesc = Object.getOwnPropertyDescriptor(
      element.prototype, "contentDocument"
    let contentWindowDesc = Object.getOwnPropertyDescriptor(
      element.prototype, "contentWindow"
    // Apparently in HTMLObjectElement.prototype.contentWindow does not exist
    // in older versions of Chrome such as 51.
    if (!contentWindowDesc)
      continue;
    let getContentDocument = Function.prototype.call.bind(
      contentDocumentDesc.get
    let getContentWindow = Function.prototype.call.bind(
      contentWindowDesc.get
    contentWindowDesc.get = function()
      let contentWindow = getContentWindow(this);
      injectIntoContentWindow(contentWindow);
      return contentWindow;
    contentDocumentDesc.get = function()
      injectIntoContentWindow(getContentWindow(this));
      return getContentDocument(this);
    Object.defineProperty(element.prototype, "contentWindow",
                          contentWindowDesc);
    Object.defineProperty(element.prototype, "contentDocument",
                          contentDocumentDesc);
   * RTCPeerConnection wrapper
   * The webRequest API in Chrome does not yet allow the blocking of
   * WebRTC connections.
   * See https://bugs.chromium.org/p/chromium/issues/detail?id=707683
  let RealCustomEvent = window.CustomEvent;
  // If we've been injected into a frame via contentWindow then we can simply
  // grab the copy of checkRequest left for us by the parent document. Otherwise
  // we need to set it up now, along with the event handling functions.
  if (injectedIntoContentWindow)
    checkRequest = window[eventName];
  else
    let addEventListener = document.addEventListener.bind(document);
    let dispatchEvent = document.dispatchEvent.bind(document);
    let removeEventListener = document.removeEventListener.bind(document);
    checkRequest = (url, callback) =>
      let incomingEventName = eventName + "-" + url;
      function listener(event)
        callback(event.detail);
        removeEventListener(incomingEventName, listener);
      addEventListener(incomingEventName, listener);
      dispatchEvent(new RealCustomEvent(eventName, {detail: {url}}));
  // Only to be called before the page's code, not hardened.
  function copyProperties(src, dest, properties)
    for (let name of properties)
      if (Object.prototype.hasOwnProperty.call(src, name))
        Object.defineProperty(dest, name,
                              Object.getOwnPropertyDescriptor(src, name));
  let RealRTCPeerConnection = window.RTCPeerConnection ||
                              window.webkitRTCPeerConnection;
  // Firefox has the option (media.peerconnection.enabled) to disable WebRTC
  // in which case RealRTCPeerConnection is undefined.
  if (typeof RealRTCPeerConnection != "undefined")
    let closeRTCPeerConnection = Function.prototype.call.bind(
      RealRTCPeerConnection.prototype.close
    let RealArray = Array;
    let RealString = String;
    let {create: createObject, defineProperty} = Object;
    let normalizeUrl = url =>
      if (typeof url != "undefined")
        return RealString(url);
    let safeCopyArray = (originalArray, transform) =>
      if (originalArray == null || typeof originalArray != "object")
        return originalArray;
      let safeArray = RealArray(originalArray.length);
      for (let i = 0; i < safeArray.length; i++)
        defineProperty(safeArray, i, {
          configurable: false, enumerable: false, writable: false,
          value: transform(originalArray[i])
      defineProperty(safeArray, "length", {
        value: safeArray.length
      return safeArray;
    // It would be much easier to use the .getConfiguration method to obtain
    // the normalized and safe configuration from the RTCPeerConnection
    // instance. Unfortunately its not implemented as of Chrome unstable 59.
    // See https://www.chromestatus.com/feature/5271355306016768
    let protectConfiguration = configuration =>
      if (configuration == null || typeof configuration != "object")
        return configuration;
      let iceServers = safeCopyArray(
        configuration.iceServers,
        iceServer =>
          let {url, urls} = iceServer;
          // RTCPeerConnection doesn't iterate through pseudo Arrays of urls.
          if (typeof urls != "undefined" && !(urls instanceof RealArray))
            urls = [urls];
          return createObject(iceServer, {
            url: {
              value: normalizeUrl(url)
            urls: {
              value: safeCopyArray(urls, normalizeUrl)
      return createObject(configuration, {
        iceServers: {
          value: iceServers
    let checkUrl = (peerconnection, url) =>
      checkRequest(url, blocked =>
        if (blocked)
          // Calling .close() throws if already closed.
          try
            closeRTCPeerConnection(peerconnection);
          catch (e) {}
    let checkConfiguration = (peerconnection, configuration) =>
      if (configuration && configuration.iceServers)
        for (let i = 0; i < configuration.iceServers.length; i++)
          let iceServer = configuration.iceServers[i];
          if (iceServer)
            if (iceServer.url)
              checkUrl(peerconnection, iceServer.url);
            if (iceServer.urls)
              for (let j = 0; j < iceServer.urls.length; j++)
                checkUrl(peerconnection, iceServer.urls[j]);
    // Chrome unstable (tested with 59) has already implemented
    // setConfiguration, so we need to wrap that if it exists too.
    // https://www.chromestatus.com/feature/5596193748942848
    if (RealRTCPeerConnection.prototype.setConfiguration)
      let realSetConfiguration = Function.prototype.call.bind(
      RealRTCPeerConnection.prototype.setConfiguration = function(configuration)
        configuration = protectConfiguration(configuration);
        // Call the real method first, so that validates the configuration for
        // us. Also we might as well since checkRequest is asynchronous anyway.
        realSetConfiguration(this, configuration);
        checkConfiguration(this, configuration);
    let WrappedRTCPeerConnection = function(...args)
      if (!(this instanceof WrappedRTCPeerConnection))
        return RealRTCPeerConnection();
      let configuration = protectConfiguration(args[0]);
      // Since the old webkitRTCPeerConnection constructor takes an optional
      // second argument we need to take care to pass that through. Necessary
      // for older versions of Chrome such as 51.
      let constraints = undefined;
      if (args.length > 1)
        constraints = args[1];
      let peerconnection = new RealRTCPeerConnection(configuration,
                                                     constraints);
      checkConfiguration(peerconnection, configuration);
      return peerconnection;
    WrappedRTCPeerConnection.prototype = RealRTCPeerConnection.prototype;
    let boundWrappedRTCPeerConnection = WrappedRTCPeerConnection.bind();
    copyProperties(RealRTCPeerConnection, boundWrappedRTCPeerConnection,
                   ["generateCertificate", "name", "prototype"]);
    RealRTCPeerConnection.prototype.constructor = boundWrappedRTCPeerConnection;
    if ("RTCPeerConnection" in window)
      window.RTCPeerConnection = boundWrappedRTCPeerConnection;
    if ("webkitRTCPeerConnection" in window)
      window.webkitRTCPeerConnection = boundWrappedRTCPeerConnection;
})('abp-request-aic05wltexc', true);. 468b7929-46c3-4249-b516-189e58962157:27:22
Another CSP:
Content Security Policy: The page’s settings blocked the loading of a resource at inline (“script-src”). Source: try { if (typeof Navigator.prototype.sendBeacon === 'function') { Navigator.prototype.sendBeacon = function(url, data) { return true; }; } } catch (exception) { console.error(exception); }. script.js:517:22
And one more (the link here has been added fyi)
Content Security Policy: The page’s settings blocked the loading of a resource at https://widget-v4.tidiochat.com//1_23_3/static/js/widget.a6a6e2b4c2401b7c523f.js (“script-src”). xgahvvrt0kwvb7p6crbxuolt4omnin1u.js:1:12450
