How? I didn’t quite understand what you mean.
I mean like swap github.com
for google.com
in the command
root@37-app:/var/www/discourse# curl google.com -v
* Could not resolve host: google.com
* Closing connection 0
curl: (6) Could not resolve host: google.com
It can’t connect because ports are closed. Are you using firewall, reverse proxy, other services, etc?
How is your setup — are you using some hosting service?
I currently have a system based on Ubuntu 18.04. I use vds.
Well, do you have ports 443 and 80 open and no other services listening those?
How can I learn this? If it were normal Linux, I could give you the information you want immediately, but I think we need to do different things here since we are using docker.
And yet Ubuntu is just ordinary linux
Sure, it can come via docker too. But I would start looking for easy and ordinary things first. Like what your UFW says.
I typed ./launcher enter app
and then entered this command:
root@37-app:/var/www/discourse# netstat -tulnp
bash: netstat: command not found
Don’t go in docker. Ask it, and ufw status
, just normally in shell.
root@37:~# netstat -tulnp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 136231/systemd-reso
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 128299/docker-proxy
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 136191/sshd: /usr/s
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 128276/docker-proxy
tcp6 0 0 :::80 :::* LISTEN 128306/docker-proxy
tcp6 0 0 :::22 :::* LISTEN 136191/sshd: /usr/s
tcp6 0 0 :::443 :::* LISTEN 128284/docker-proxy
udp 0 0 127.0.0.53:53 0.0.0.0:* 136231/systemd-reso
root@37:~# ufw status
Status: inactive
Try this:
If it doesn’t help then you know the issue may be docker itself.
I followed the steps in the article you gave, but I still get the same error. What should I do now?
Have you red this:
Or this:
Or this:
There are several topics that are close to same issues you have.
Sorry, but I have sub-zero knowledge of docker
It seems like some networking issue. You might try copying /var/discourse to a new server, especially one with a different hosting service.
There’s a topic about moving to a different server. Move a Discourse site to another VPS with rsync
What kind of server are you attempting to launch discourse with?
A $12/month server with this platform will work with the standard install procedure:
I don’t know if it is matter of money because that Discourse can’t see the outside world
This does look like the problem, probably asking server administrator/help desk would be a good first step if there is no connection to the internet.
One has to be careful here not to conflate two separate problems while troubleshooting. Incoming ports being closed does not affect outgoing connections.
The best first step here is probably a reboot to ensure that the networking stack and Docker initialise cleanly.
And yet most of admins are using UFW and it takes care both directions.
