Incoming Email - Only first recipient is handled
An old bug has resurfaced because some users didn’t get an important info. :frowning:
I noticed that the initial report is located unter support and not here under bugs.
@moderators feel free to merge and locate everything here under bug if split/double posts are a problem. Thank you very much.
Detailed report
Summary
An incoming email (via POP3) hat the address from multiple discourse-groups (email-enabled) in the To-Field. Only the first hit is processed. All other groups are not invited to the new topic (
@evantill found the code that handles the incoming mail:
I can understand some of the code, but I’m not able to make a qulity pull request.
How can I help to get this fixed? At the moment I have to manually add all recipient groups to the automatic created message for the first recipient-group.
