Incorrect usage of week/month/year units in a translated string
The topic_stat_sentence translateable string looks like this:
topic_stat_sentence:
  one: "%{count} new topic in the past %{unit}."
  other: "%{count} new topics in the past %{unit}."
And upon formatting this string at category-list.js.es6 count is applied as a plural argument, but the thing is that this is not enough, there are 2 issues for some languages:
  • unit can be not in nominative form here, so it is not correct to simply use translation of js.week string (for example ) as a unit
  • in the past part translation can change too depending on the unit value
For example in Russian the phrase in the past %{unit}% translates differently depending on unit:
week → “за предыдущую неделю”
month → “за предыдущий месяц”
day → “за предыдущий день”
minute → “за предыдущую минуту”
things to note above:
  • in the past (за предыдущую) changes depending on unit
  • {unit} is not nominative in the translation. Nominative for week/month/day/minute is неделя/месяц/день/минута, but in the phrase we use неделю/месяц/день/минуту for Russian.
Current behavior
is to translate in the past week as “за предыдущий неделя” which has both words wrong.
Proposed solution:
Unit should not be used here separately, instead the whole in the past week/month/day/year phrase should be made available for translation as 3 (or 4?) different translatable strings.
4 个赞
I brought that up 4 years ago in https://meta.discourse.org/t/its-not-possible-to-correctly-translate-topic-stat-sentence/18359
This could be a great #starter-task if someone wants to fix the translation. :wink:
I’d recommend replacing the existing translation with 4 new ones:
  • topic_stat_sentence_day
  • topic_stat_sentence_week
  • topic_stat_sentence_month
  • topic_stat_sentence_year
7 个赞
Hi @gerhard
I saw code corresponding to it, topic_stat_sentence string is used for translation only when unit is month or week. I have started with them only for now.
I m not an expert at translating so I have just added new variables and kept things backward compatible till we have translations available.
PR for same: FEAT: split topic_stat_sentence to topic_stat_sentence_week and topic… by mrfinch · Pull Request #6663 · discourse/discourse · GitHub
Let me know if that works.
Thanks
3 个赞
PR has been merged. Thanks @saurabhp! :+1:
The old string was replaced with the following two:
6 个赞
