I think I’ve got everything setup, but the Initial Update Patreon Data & Sync Groups doesn’t seem to work. I’ve double checked my settings. I’m running the latest tests-passed.
Where should I look? The button flashes slightly when I click it, but that’s about it.
-Mac
Is there any errors in /logs after you did the manual sync.
8BIT
20 במרץ, 2018, 2:44am
3
it says 4 days ago but that’s not true as new subscribers have gotten their flare / badge… something’s not updating correctly.
/var/www/discourse/plugins/discourse-patreon/lib/pledge.rb:57:in `merge!' /var/www/discourse/plugins/discourse-patreon/lib/pledge.rb:57:in `block in save!' /var/www/discourse/plugins/discourse-patreon/lib/pledge.rb:54:in `each' /var/www/discourse/plugins/discourse-patreon/lib/pledge.rb:54:in `save!' /var/www/discourse/plugins/discourse-patreon/lib/pledge.rb:45:in `pull!' /var/www/discourse/plugins/discourse-patreon/lib/campaign.rb:38:in `update!' /var/www/discourse/plugins/discourse-patreon/lib/patron.rb:7:in `update!' /var/www/discourse/plugins/discourse-patreon/app/jobs/scheduled/patreon_sync_patrons_to_groups.rb:9:in `execute' /var/www/discourse/app/jobs/base.rb:134:in `block (2 levels) in perform' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-2.0.4/lib/rails_multisite/connection_management.rb:63:in `with_connection' /var/www/discourse/app/jobs/base.rb:129:in `block in perform' /var/www/discourse/app/jobs/base.rb:125:in `each' /var/www/discourse/app/jobs/base.rb:125:in `perform' /var/www/discourse/app/jobs/base.rb:180:in `perform' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:188:in `execute_job' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:170:in `block (2 levels) in process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:128:in `block in invoke' /var/www/discourse/lib/sidekiq/pausable.rb:80:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:130:in `block in invoke' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/middleware/chain.rb:133:in `invoke' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:169:in `block in process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:141:in `block (6 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_retry.rb:97:in `local' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:140:in `block (5 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq.rb:36:in `block in <module:Sidekiq>' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:136:in `block (4 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:204:in `stats' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:131:in `block (3 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_logger.rb:7:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:130:in `block (2 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/job_retry.rb:72:in `global' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:129:in `block in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/logging.rb:44:in `with_context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/logging.rb:38:in `with_job_hash_context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:128:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:168:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:85:in `process_one' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/processor.rb:73:in `run' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/util.rb:16:in `watchdog' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/sidekiq-5.0.5/lib/sidekiq/util.rb:25:in `block in safe_thread'
@8BIT It may updated through webhooks. Are you sure about the scheduled sync job in sidekiq running without fail?
@ninermac this is backtrace. Can you share the error message too. Also do you have active Patrons?
Job exception: no implicit conversion of nil into Hash
No active Patrons. Do I need an active Patron? I can jumpstart it myself if that’s the case.
Thanks
Last time I checked, this is created on first sucesfull sync, that fails for you because there are no patrons.
Yes, you need some Patrons for the successful sync.
Anyway it shouldn’t raise the error if there are no Patrons. Added to my list with low priority.
