Installation on DigitalOcean with 1GB RAM complaining
Using the guide at discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub, I’m trying to install discourse on a DigitalOcean droplet with 1GB RAM. the discourse-setup script says I need to configure a swap file. DigitalOcean does not want me to use a swap file. At the top of the Discourse install guide, it says that a 1GB server is sufficient. How do I continue without using a swap file? The only option is to continue or exit the discourse-setup script.
You continue by using a swap file. DigitalOcean doesn’t want you using a swap file because they can then sell you bigger droplets.
「いいね!」 5
And you need a swap file with a 2gb droplet too (but only during upgrades).
「いいね!」 1
このトピックは2713日後に自動的に閉じられました。新しい返信は許可されていません。
