Installing Discourse as a subdomains
Hello,
I’ve been getting my hand dirty with Discourse on my localhost. I find Discourse just amazing and exactly what I need, so thank you to the Discourse team for creating such an amazing discussion platform.
My question is, how to install Discourse as a subdomain. Many websites use Discourse as a subdomain (including Discourse website) and have a separate static web page. I would like to do the same. Is that possible, and are there instructions I can follow in order to accomplish that task?
Thanks,
Just follow the install instructions.they assume that discourse will be on a sub domain.
Thank you. Just one question though. Is there a difference between the 30 minutes cloud install provided in this link: discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub and the other installation options. In other words, what would be the best installation option that I could follow?
The difference is that the instructions you linked to are what we support. Any other instructions or installation method may produce unexpected and/or amusing results.
Thank you, Matt. I completely understand but what I wanted to know was the difference between the Beginner Docker install guide and Advanced Docker install guide in this page: discourse/docs/INSTALL.md at main · discourse/discourse · GitHub
In other words, what advantages does one have over the other besides the installation duration?
Complexity. The 30 minute install is designed for a typical small to medium site. Large sites usually have special needs and the advanced install allows more configuration for those special needs.
Now I understand. Thanks a lot.
I think I will just use the 30-minute install for now just so I can have an idea about how things work, then later if I wanted, I can reinstall using the advanced Docker install.
