Invalid parameters to the request: limit
The discussion, titled “Invalid parameters to the request: limit,” reports an error when loading the tag list in the Discourse platform. Dayoung_Lee encountered the issue while using the API, specifically with the limit parameter in the endpoint https://{{company name}}.discourse.group/tags/filter/search. pfaffman questioned whether the issue was API-related and asked about the user interface input. JammyDodger acknowledged multiple reports and moved the issue to bug for investigation. fzngagan confirmed the issue stems from the max tag search results site setting being set above 50, and noted that reducing it resolves the error. A fix is currently in progress.
When creating a new topic or making changes to the tag settings within a tag group, I am encountering the following error alert. This alert prevents me from using the tag functionality. Could you please help me identify the necessary steps to resolve this error?
I am sharing the API endpoint and request related to the part suspected to be causing the issue. Please review it quickly to identify the problem.
[Issue Description]
  • There is an issue with loading the tag list.
[API Endpoint and Request]
  • API Endpoint
(https://{{company name}}.discourse.group/tags/filter/search?q=&limit=2048&categoryId=&filterForInput=true)
You’re doing this with the API?
If so, don’t include the limit parameter. If not, what are you entering in the ux?
We’ve received a couple of reports of this now so I’ve slipped this over to Contribute > Bug while we investigate further. :+1:
Hi Young,
I just tested and the error isn’t there on your site. Actually, the issue is related to max tag search results site setting when its set to a value above 50. As you’ve reduced it the error is gone. We’re actively working on a fix and will let you know once the fix is in place.
